I have a set of 4 super-wide/super-lightweight 17"x9" Enkei RP01 wheels and tyres for sale.
Offset 17 x 9JJ 22
Two of the tyres are what everyone could consider unroadworthy, and the other two have tread but are a little scrubbed on the edges due to the camber my GTR was running. There is a very small curb scratch on one wheel that is cosmetic and the wheels are in very good condition otherwise never had accident damage or been repaired.
I have attached some Pictures of the wheels whilst they were on my car in Japan. The wheels are Located in Melbourne South-east suburbs, pickup would be preferable.
Wheels will suit all skyline models, they fit perfectly on the 32, so 33 and 34 are safe!
I'm looking for $1,100 PRICE DROP $750....
Don't miss out on these awesome classic wheels!
Edited by zandi2000
https://www.sau.com.au/forums/topic/174348-soldplease-close-thread/
i wish you were in sydney!
i have a set of R33 GTR wheels for sale... but when i bought them i was looking for these.
would you be at all interested in a swap? less the tyres
would basically be willing to drive down to swap? are you interested?
Drive from Sydney to swap!? wow... i appreciate your effort man but im in a bit of a money crisis at the moment and would prefer cash, if you can muster up the money i could potentially freight them up to Sydney for you.... sorry mate
A bunch of you guys have shown interest in the wheels but I havnt seen the money in my bank.. comon people take these lightweight Japanese wheels off my hands!
Pm's sent...Ok guys didnt intend this to drag out this much.. will accept offers over 850.. its rediculous how much im losing on these stupid wheels.. my shipping receipts will prove that!!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
