maybe out as i blew my turbo today :(:( will let you know in the next few weeks as my cabin spot may go up for offer
Awwwww you weren't kidding about there being no exhaust wheel :P
btw let me know if you want that other turbo..... it will get you through DECA at least :)
  • Replies 951
Mr Moo isn't entered in DECA is he?
Or is this Nigel?
ummmm guess not?? I think he must be doing Winton then spectating ? Can't see his name on the list for DECA...
My mistake, your fault............. lol :)
i wouldn't, not with your record of losing GTR's :P
:D I did not "lose" them.... one decided to grow legs and walk away of its own accord, and the other well.... a truck decided it looked better with my car attached to the front of it....
Soooooooooooo dropped :)
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
