maybe out as i blew my turbo today :(:( will let you know in the next few weeks as my cabin spot may go up for offer
Awwwww you weren't kidding about there being no exhaust wheel :P
btw let me know if you want that other turbo..... it will get you through DECA at least :)
  • Replies 951
Mr Moo isn't entered in DECA is he?
Or is this Nigel?
ummmm guess not?? I think he must be doing Winton then spectating ? Can't see his name on the list for DECA...
My mistake, your fault............. lol :)
i wouldn't, not with your record of losing GTR's :P
:D I did not "lose" them.... one decided to grow legs and walk away of its own accord, and the other well.... a truck decided it looked better with my car attached to the front of it....
Soooooooooooo dropped :)
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
