Hi all,
My S1 R33GTS-T may be having some oil pressure issues. On start up the gauge reads 6kg/cm2, and when the car warms up it generally reads about 4kg/cm2 at 3000rpm. This all seems reasonably healthy for 4100 turbolite oil AFAIK.
The problem is that sometimes (randomly) the gauge will start reading 2kg/cm2 at 3000rpm, and will drop to 0.5kg/cm2 at idle. Then later it will return to normal.The engine doesn't seem to get any noisier, and if the gauge wasn't there, I wouldn't know there was an issue.
The oil pressure light doesn't come on (although it does work on engine turn-over).
I have ordered a sandwich-plate and OP gauge from JustJap, to check the gauge and sender. I was hoping someone else may have better insight on what might be going on. Should I be preparing for a new oil-pump?
If so what's a new standard pump worth? :-)
TIA
PS- I searched, but no other threads were quite the same problem.
https://www.sau.com.au/forums/topic/174367-another-oil-pressure-question/
If you find the stock guage is reading correctly then you won't be up for just an oil pump. Rebuild time. :/
Do you mean that the oil pressure problems is due to a stuffed engine... or that I've stuffed the engine by driving around with low pressure?
What do you think the problem might be?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
