You have to run an external pick up.
I've attached a couple of pics from another setup I've seen.
I'm not sure if using a banjo is a wise idea but it did appear to work with no issues; I would prefer a speedflow type connection.
Hi Felix, here are some more pics of mine. Notice that there is a -12 fitting welded to the side of the N1 Pump and pointing in the direction of the A/C Bracket. This then goes to the fitting you see on the side of the sump. The connects up to the pick up inside. I've also put in a pic of the fitting at the back of the head that is the oil return to the sump and a pic of the internals of the sump showing the trap-door arrangement in case any of that helps..
like the others said, u need to run an external oil pickup, exactly as r32 tt has in the pics.
On a side note, did u get that adapter plate from a guy off here? If so good luck in getting it to fit, i got one and decided to throw it in the bin and make one myself :P Plus i can get them remade aswell :D
P.S sweet lookin sump matt :D i decided to go for a dry sump setup :P
Guys where did you get your adapters from? I've seen the ones Pro Engines are making and they don't look like that. There was someone else making plates and I understand they had a few issues.
Hi Mark, thats not one of mine. Mine uses either a bolt on internal pickup or a blockoff plate for the pickup hole if you're using an external pickup. The bolts fit properly, all the drilling, countersinking and tapping is done in a CNC mill, as well as the silicone groove. Pick below to show the difference.
Cheers,
Greg.
Cheers,
Greg.
I know mate, my point was that I've seen yours and they're bloody good.
yes, where did you guys get these poor fitting adapters from. I'm sure many of us could benefit from your hard bought wisdom!
Greg, that looks nice. >_<
Fitzpatrick Speedworks
I'm still waiting for my $150 refund that he promised...
There definitely appears to be some fitment issues with these adapter plates. My mechanic had the same alignment issues with many of the pre-drilled holes. Additionally there was significant grinding required of the block to leave enough room to put in some of the connecting bolts for the sump. Mine leaked like a sieve when we got it running.
On another note my oil pick was cut and refabricated to stay internal.
Andrew
hi guys, i have purchased the pro engine kit for mine. will be building it ip in the next few weeks will post a thread, but as for now it looks a superb bit of kit with internal pick up too. ideal for me as i like my air-con..bernie uk..
to add to my reply.
the bolt holes on the sump adapter is not stright, and doesn't light up the the holes on the sump.
gary said every RB motor is differen't but mine is clearly showing that gary's machinest just have bad eye sight and can't see stright.
if u guys remember that RB30 i had him build and we waiting a year and half for the block.
well now it has to be taken apart again and re machine it.
-piston walls are really scratched from them forcing the piston in.
-the holes fo the head bolt was drilled and tapped for bigger head studs, but he didn't drill it stright so the head and the head gasket won't go in. it's clear that 5 of them needs to be re drilled.
-improperly packing made the piston top all scratched up, from shipping.
-sump adapter needs to be re made as the plate it self isn't even flat. and the holes were off.
-block was cracked at the stock oil pick up. part of the casting.
this is a big pos
sorry i went off topic
    • I have no hard data to report, but I have to say, having driven it to work and back all week, mostly on wet roads (and therefore mostly not able to contemplate anything too outrageous anywhere)..... it is real good. I turned the boost controller on, with duty cycle set to 10% (which may not be enough to actually increase the boost), and the start boost set to 15 psi. That should keep the gate unpressurised until at least 15 psi. And rolling at 80 in 5th, which is <2k rpm, going to WOT sees the MAP go +ve even before it crosses 2k and it has >5 psi by the time it hits 90 km/h. That's still <<2.5k rpm, so I think it's actually doing really well. Because of all the not-quite-ideal things that have been in place since the turbo first went on, it felt laggy. It's actually not. The response appears to be as good as you could hope for with a highflow.
    • Or just put in a 1JZ, and sell me the NEO head 😎
    • Oh, it's been done. You just run a wire out there and back. But they have been known to do coolant temp sensors, MAP sensors, etc. They're not silly (at Regency Park) and know what's what with all the different cars.
    • Please ignore I found the right way of installing it thanks
    • There are advantages, and disadvantages to remapping the factory.   The factory runs billions of different maps, to account for sooooo many variables, especially when you bring in things like constantly variable cams etc. By remapping all those maps appropriately, you can get the car to drive so damn nicely, and very much so like it does from the factory. This means it can utilise a LOT of weird things in the maps, to alter how it drives in situations like cruise on a freeway, and how that will get your fuel economy right down.   I haven't seen an aftermarket ECU that truly has THAT MANY adjustable parameters. EG, the VAG ECUs are somewhere around 2,000 different tables for it to work out what to do at any one point in time. So for a vehicle being daily driven etc, I see this as a great advantage, but it does mean spending a bit more time, and with a tuner who really knows that ECU.   On the flip side, an aftermarket ECU, in something like a weekender, or a proper race car, torque based tuning IMO doesn't make that much sense. In those scenarios you're not out there hunting down stuff like "the best way to minimise fuel usage at minor power so that we can go from 8L/100km to 7.3L/100km. You're more worried about it being ready to make as much freaking power as possible when you step back on the loud pedal as you come out of turn 2, not waiting the extra 100ms for all the cams to adjust etc. So in this scenario, realistically you tune the motor to make power, based on the load. People will then play with things like throttle response, and drive by wire mapping to get it more "driveable".   Funnily enough, I was watching something Finnegans Garage, and he has a huge blown Hemi in a 9 second 1955 Chev that is road registered. To make it more driveable on the road recently, they started testing blocking up the intake with kids footballs, to effectively reduce air flow when they're on the road, and make the throttle less touchy and more driveable. Plus some other weird shit the yankee aftermarket ECUs do. Made me think of Kinks R34...
