I just found this on another forum and had a good laugh...
Does anyone actually think this would work ?
http://www.riverinacars.com/forum/viewtopi...p?p=37966#37966
Hey guys,
Ive always been facinated as to why people put on huge intercoolers to cool intake air, but dont cool the other crucial element of the combustion system: fuel
Basically, an engine needs two things to run: Fuel and Air. The colder the incoming air or fuel, the denser it is, thus the more air and fuel that can be packed into the combustion chamber, and the more that is burnt in the explosion (less wasteage)
This in turn makes more power, and more power means more fun!!!
I had a big problem last year with my Gem during the 40+ degree summer. The car was very laggy, and a downright pain to drive, due to the heat.
I created an intercooler spray system, that sprayed directly onto the front and rear of the main core that was operated off a manual switch inside the cabin.
This did have alot of effect on the car at 50kph or more (Air temp - 40 degrees down to 20 degrees = 50% reduction).
NOTE: Intercooler cost over $2k from Mr Enforcer Engineering, and was custom built for my Gemini.
Now, Im pretty unsure of water injection setups. The idea of water pouring into the combustion chamber really freaks me out. My grandfather has done alot of work with such setups from the 50s onwards, and has had great success.
Ill be looking more into this at a later date.*
These setups Ill be looking at using on my next car, as I think nothing will save the Escort
Ive done a bit of research into basic fuel cooling setups, but havent come up with much. Seems there isnt much a need out there, but plenty for huge truck intercoolers.
I have to stress the ice wont last forever, and that its not ment to be a permanent solution to the problem, although the empty box would also double as a heat sheild around the fuel line.
So here goes. Anyone with ideas, please post up at how I can improve my design.
CUSTOM FUEL ICE BOX
* The box or cylinder will be lined with a dense foam, so the ice dosent come into contact with the sides. The metal exterior will be hot from the engine bay, and will cause the ice to melt faster.
* The fuel line will be coiled/spiralled around a central point. Corners would create pressure, and slow the flow speed of the fuel.
* Ice will be packed around the the spiralling fuel line. NOTE: the coil has plenty of width to the outer edge, so ice can be packed in.
* The box will have a drainage outlet, that would pass into the radiator overflow tank.
Its all about R & D. Lets go!!!
Edited by MintR33
https://www.sau.com.au/forums/topic/174513-custom-fuel-ice-box/
I know petrol has a stupidly low freezing point so that won't be an issue, but, won't that seriously mess with the fuel atomization?
As we all know, cool air has more oxygen per given volume allowing you to put more fuel in and make more power. The same can't be said for petrol, cooling it does nothing to the overall volume so why would you bother?.
Contrary to popular belief, water injection has NOTHING to do with "cooling" the fuel, it is there simply to reduce the chances of preignition (pinging) in high compression or blown engines.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
