This group buy is now closed.
This has turned into a brake and clutch line group buy now.
Replaces the stock assembly including the damper. Makes bleeding the clutch easier and releases the clutch faster once you take your foot off the pedal.
Braided line comes with banjo bolts, sealing washers and heat sleeve.
I'm organising this group buy with UAS.
Fits R32, R33, R34, GTST, GTT, GTR.
Retail $120. If we get 10 people They are $80 delivered.
Group buy will run until end of August.
Ok I've got the details on the braided brake lines that everyone wants:
Goodridge lines ADR approved, anti wip and no rubber like other brands on joins which perrish with heat. Bolts straight on, made in England and quality product. Exact same as V8 Supercars use.
5 or more sets $195 each set of 4 instead of $260 Freight and handling anywhere in Australia $15
Clutch line:
1. Omurru - pm sent
2. 2GU UP - pm sent
3. gtst25 - paid
4. kgleeson (UK) - $35 to UK - paid
5. GTRgeoff x2 - paid
6. Dave R31 - paid
7. hayden49 - paid
8. Reggi34dr - paid
9. made_guy - paid
Brake lines:
1. apple_eater - out
2.
Both:
1. JETR-32 - pm sent
2. arep3 - paid
3. gt-t_r34 - pm sent
4. Cerbera - pm sent
5. sam5709 - pm sent
6. msnismo - paid.
7. tek_01 - paid
8. made_guy - pm sent
9. mic_check_1_2 - pm sent
10. LadyBytes - paid
11. khunjeng - paid
12. Strykr 33 - paid
13. Fujiwara - paid
Note:
By accident and coincidence there are two group buys involving braided brake lines.
Marks lines are ADR approved, meaning compliant and tested, and will be road legal. My lines are ADR compliant only and more suited to race use.
Neither of us is a business so this is not a competition. Which ones suits you is up to you.
https://www.sau.com.au/forums/topic/174663-braided-clutch-and-brake-lines/
  • Replies 97
I can check on brake lines. Might do a gb on them after this one.
If you go straight to UAS you wont get this price but that is where I'm getting them from.
I'll check on install price. Earls do the heat sleeve.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
