i know i should have expected this when i bought a import but i didnt think it would be so bad,it must just be me but i cant find ANYTHING,those clunks in the front,every suspension place just says they cant look at it cause it is a import and they cant do anything,does anyone in perth know a good suspension place to get it fixed and maybe a new suspension set up?? thanks
https://www.sau.com.au/forums/topic/174776-change-of-heart/
Shayne have you gone to places like WA Suspension in Ossie Park ( www.wasuspensions.com.au) or Wilkinson suspension in Bayswater??? Both of these places are highly recommended through the import scene and Wilkinson's is a SAUWA Club member Discount place...so obviously these places deal with imports???
*edit* sorry didnt realise that you were south of the river, but obviously if no one is willing to help your way it may be worth a phone call to one of these two places and tell them your issues as well and see what they can offer you before you head up to them*
https://www.sau.com.au/forums/topic/174776-change-of-heart/#findComment-3205741
dunno what cha on about....
talk to Sydneykid and buy his "groupbuy" stagea suspension setup
front and rear adjustable Whiteline swaybars
front and rear Whiteline bush kits
front and rear Bilstein shocks with circlips
use stnd suspension springs.
fkn awesome
then get the turbo highflowed, full free flowing exhaust, fmic, boost to 1.1bar, tune with safc and fuel pressure regulator and z32 afm.
200awkw right there with handling to boot
- fkn easy
https://www.sau.com.au/forums/topic/174776-change-of-heart/#findComment-3205787
Wheels World in Osb Park to be sure to be sure.
you should just SEE some of the cars they work on .. Iam sure they can nut out what is going on with your stagea. and yes.. I think the Sydneykid Group buy on the suspension would be a good idea!
Morethan likely if you installed the suspension group buy kit the clunk might disappear.
you sure the clunking is not a CV joint or a Engine mount
https://www.sau.com.au/forums/topic/174776-change-of-heart/#findComment-3207650
Well I went and got my creaking and clunking diagnosed at WA Suspension in ozzy park! (FREMANTLE store is CLOSED :) )
It is a camber pin and my castor rod bushes need replacing.
Stagpower, ONLY reason I went to get my clunking diagnosed, was we found my left hand front tyre split and bald on one part of the edge! Will upload pics soon.
post-30699-1183380948_thumb.jpgpost-30699-1183380910_thumb.jpgpost-30699-1183380855_thumb.jpgpost-30699-1183380802_thumb.jpg
https://www.sau.com.au/forums/topic/174776-change-of-heart/#findComment-3209319
thanks everyone,will try them and see what happens,i would love to get the group buy susp kit but i dont know about you's but i aint made of money......i am getting a fmic and exhaust next fortnight too :):)
https://www.sau.com.au/forums/topic/174776-change-of-heart/#findComment-3209396
thanks everyone,will try them and see what happens,i would love to get the group buy susp kit but i dont know about you's but i aint made of money......i am getting a fmic and exhaust next fortnight too :dry::)
roger - I hear you there.... saved for a while to 'afford' some suspn goodies from the group buy. didnt bother with springs (have some, lol, stnd is fine, didnt have the money) and the rear bilsteins I got were slightly used so got a better price on those. But the stnd struts were well past their use by date, safety factor etc with kiddies. I guess I made myself afford the upgrade !!!
good luck with the upgrades tho, little by little, but then again modifying a car is 'hardly' worth it, I suppose.
https://www.sau.com.au/forums/topic/174776-change-of-heart/#findComment-3209901
thanks everyone,will try them and see what happens,i would love to get the group buy susp kit but i dont know about you's but i aint made of money......i am getting a fmic and exhaust next fortnight too :domokun::)
I'm at the point where I dont want the car to necessarily go any faster. It should be capable of mid 14 sec 1/4 mile times as it is so I'm happy with that.
I have the exhaust but I need a fmic, but in many ways I would prefer a suspension upgrade before anything else now. If I was to do it all again I'd probably do suspension first. I think it would make THE biggest difference to driving the car. Exhaust would be a close second...as that is possibly the most important performance mod...without one no other performance mod is really worth it. :blush:
https://www.sau.com.au/forums/topic/174776-change-of-heart/#findComment-3210659
I managed to pick up the suspension from Marc's first Stag that met an untimely end.
I have the same setup as tangles I think
Front and Rear Bilsteins
Adjustable front swaybar
Rear swaybar
Standard Springs
The ride is definately firm, and you feel the road more in normal driving. The cornering is MUCH better. It is much flatter through corners, and driving in the wet is reassuring. The suspension soaks up large bumps much better.
Its taken a while to get used to, but I definately prefer it to standard. The new Auto Centre bush has really helped reduce the driveline vibration and movement.
Next thing is to hook up the new head unit, and hook up the IEBC and DFA........Better get a soldering iron!
https://www.sau.com.au/forums/topic/174776-change-of-heart/#findComment-3213272
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
