Hi all I have finally got myself a R32 GTR, picked it up yesterday, It goes in for Roadworthy tommorrow at Gavin Wood also getting him to do a Diagnostic and a general check over of the car.
I am hopping all is good with the car and all the hardware is in good nick keen to try and get around 300kw atw where do you guys recommend dyno tuning, car has a Power FC, i think Gavin Takes the cars to matt spry, just wondering if there are any opinions on the tuning ?
I bought Mitchy's car from Sydney, found a few things that I have fixed today, here are pics and specs if anyone wants a look
HKS GT-SS Sports Turbines - Ball Bearing 320hp each
HKS Split Dump Pipes
HKS stage 2 cams and springs
Twin 3" Front Pipes into single 3.5" Exhaust. N1 Style Muffler
N1 Oil pump
N1 Water Pump
OS Giken Triple Plate Clutch R3C
Lightened Flywheel
Genuine Nissan N1 Block ($3,500)
GTR Crank (replaced)
Adjustable Cam Gears
Apexi Power FC 'Plug N Play'
Apexi Electronic Boost Controller Kit
Apexi FC Commander Hand Controller
Apexi Super Intake kit for 80mm AFM's
Apexi GT Spec Intercooler (no longer in production) 136mm Thick
R33 Gtst 80mm AFM's <Used
Greddy/Trust Oil Catch Can
Greddy/Trust Intercooler Piping Kit
CP Forged Pistons
Tomei Metal Head Gasket
NISMO Fuel Pump
600cc injectors
Apline MP3 Headunit w/remote
Alarm System with Remote Central Locking
Bride Reclining Racing Seats (possibly non-genuine?) w/genuine rails, nearly new
Nismo Duracon Gearknob
TEIN Super Street Coilovers (Adjusted for Australian Streets, Height and Dampening Adjustable)
Front Strut Brace
Michelin Pilot Preceda Tyres on stock GTR rims
Slotted Brake Rotors and Bendix Pads
https://www.sau.com.au/forums/topic/174912-where-t-get-dyno-tune-done/
I dont mind saying at all i ended up getting it for 27k, needs a few little things done, 2nd hand compressor for AC, Left hand air vent needed and new oil pressure sensor on the engine other then that all is sweet.
I really hope it all goes well with tuning and the gear thats on there.
Trying to get used to the clucth atm triple place :| I have driven friends 33 GTR and it has a heavy clutch but man this thing bites hard..I hope to master in in the next week, hill starts :|
Edited by Mark0
I dont mind saying at all i ended up getting it for 23k, needs a few little things done, 2nd hand compressor for AC, Left hand air vent needed and new oil pressure sensor on the engine other then that all is sweet.
Thats pretty good price considering the shit you got there
A triple plate clutch will give a new whole meaning to hill starts. I was stalling a few times when i first got my car its an embarressing time til you get the hang of it.
Just let that clutch out nice and easy til you feel the bite and let ya handbrake go. Good luck with it.
booyah..
that is nice..
300kw atw shouldnt be too hard to get mate :)
let us knw how it goes..
sorry but do R33 GTST use an 80mm AFM.. in ur post it says it does.. just wondering about that..?
r33 and r32 GTSTs use an 80mm AFM green sticker for r32 and s1 r33 pink sticker for s2
what he said :)
yer the car is with Gavin atm getting roadworthy and a check over, then I will look at tuning after i see what gav says (power wise) I am getting used to the clutch no stalls this morning 1 bunnyhop out of about 15 sets of lights, I amhappy with that :(
i had to go to bridal expo yesty I went all good until getting up the hill in the undergound parking, cause the cars were linned up stalled once, spun the wheels then got up the top lol
Edited by Mark0
ta andy :domokun:
80mm internal diameter
Z32 has 80mm internal diameter but a greater voltage range
yeah we used a Z32 on the Rb20 sil as it came with the z32 lol...
when does the air flow run low on the R32 / R33 afms? more so when will the R34 run out of puff afm side>?
oh really so the actual afm isn't less restrictive - its the signal it outputs that matters
might take mine off and get the multimeter out on the weekend
see if its all still good...
ps. sorry for the sidetracking - will stop now!
pps. thanks for the help Andy
well she passed rego, feels good to have those plates on my car, as soon as I get some more $$ will go back fro tunning and go for around 300-310 kw atw (which should be a safe tune for this engine) then replace a few bits of interior then that will do for a bit till I can afford some wheels
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
