  • Replies 93
hey funky,
can only find the torrent for eps1 and 2 :P
if youre checking my suggestion of going to anime suki, then yea they only have the first two.
use a keyboard. Thats what google is for.
lol i did but could only find the eps1 and 2. Im playing the ps3 game and its all in Japanese, so i cant understand the story line lol need to watch the anime to get up to speed
TV-Links has the first two episodes up too, not sure how good they are quality-wise, but I'm about to find out. I guess I'll have to use YouTube to see the other episodes for now.
the stories a bit creepy isnt it?? i mean..who REALLY talks to their car like that?? actually, who talks to their car AT ALL??
bloody ijjit. he gets his car flogged not once but TWICE by two chicks and both times right in front of him!! And he sits there all..Im the man Im the man..dont trash my car man, but if you do its kewl...
didnt someone just say that initial D story line was crap?
considering this is from the same studio house, thats a compliment. :closedeyes::P
Umm... Up to Ep.6 Part 1/3.
Need 2/3 and 3/3 if anyone knows where to find?
With subtitles please :domokun:
wtf? mate check you tube, its up there with subs..
type : wangan midnight 6.
Does the show get less annoying and stupid?
As wanky as they were, at least Initial D talked about driving techniques and other junk like that.
The most airyfairy they got was with the car's "aura".
But Wangan Midnight was just ghost cars and a guy being a jerk to some chick he has had a crush on for ages... does it improve?
they are all RAWS for me. Without subtitles.
Wtf?
You need the SEVS one.
Thank you!! I'll be here all week!
I actually watched that movie... it was soooooooooo bad
But it didn't quite make that loop around to being so bad it was good again...
I need to finish the review I half wrote for it.
Edited by Laurence
haha shuto trial was da bomb! wasnt that the one with tsuchia (iono how 2 spell his name...aka the DK~) and u get to see a silvia and an fc go drifting? lol if its the same movie, dammit it was pretty cool hahaha
just out of curiosity, does anyone have any copies of シャコタン ブギ or Shakotan Boogie?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
