  • Replies 93
  • 4 weeks later...
  • 1 month later...
Do people really think this is good entertainment? I've watched a number of episodes now and they don't seem to be getting any better. I mean the show is just based on cars speeding on straight road, reach the slightest corner and some one crashes. The lengthy dialog and repetitive thought process of the drivers really makes the show a drag. The only appeal it has going for it are the cars. To me it just seems like a lame rip off of Initial D except without any form of storyline.
/Late night rant over.
Edited by BAMR33
didnt notice this on the skyline page,
here's where i been getting my subtitled ep's they only up to the same as you guys though but they crazy obsessed with it so they might get the new 1s before someone on here spots it
http://idforums.net/index.php?showtopic=28289
i wanted a z before this come out, even went out n test drove a midnight blue 240z (2 seater edition) had a smile on my face the rest of the day :whistling: even though when looking at it close it was a piece of sh*t and i wasnt prepared to pay so much for a car that was obviously held together by rust and half ass paint job to try n hide it. possibly it was the devil z ready to kill someone
most notable thing bout driving 1 it feels like your sitting in the back seat, as with the long bonnet and short ass you pretty much are.
i wanted a z before this come out, even went out n test drove a midnight blue 240z (2 seater edition) had a smile on my face the rest of the day :) even though when looking at it close it was a piece of sh*t and i wasnt prepared to pay so much for a car that was obviously held together by rust and half ass paint job to try n hide it. possibly it was the devil z ready to kill someone
Definately, you have to change your thought process to turn at the right time or you end up turning late etc.
The prices went up hardcore for a few months this year and you will pay about 15k for a decent condition one that would have been about 8k 6 months ago. It seems to happen every year, but they dont tend to go down cos no one really wants to get rid of them, so they wait till someone offers the right money. Its usually the missus making them sell :( As far as im concerned, if you hook up with me, you hook up with my zed too :) (not litterally, though maybe on the bonnet would be ok, as long as theres no scratches, dents, stains etc) and i make it very clear when starting out. So far only one chick hasnt liked it calling it a "penis extension" damn straight and what an extension!!! Needless to say I kicked her to the curb.
End 3.30am rant
  • 1 month later...
Ep 13 & 14 finally here, been a long wait!!
Raws, of course.. translations will be a while away. And if anyone was wondering, yes the story does get much, much better.. I started off comparing to Initial D (Which I still love) and was disappointed, questioning whether this would be any good, but it's worth the wait. Stick with it - I am so addicted to Wangan now.
Torrent Link
I just got in the mail Episodes 1-12 from EBAY
Episode 1-6 for $8.00 US
and 7-12 also $8.00 US
with English subtitles
Edited by spx25t
  • 1 month later...
Up load 7-12 to youtube for me LOL
Better yet upload ep7-14 on veoh.com - Vids tend to last longer on that site, and the quality is far better. I must be way behind now. I've still only seen up to the end of ep6 subbed version.
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
