Come along anyway Marco, gotta meet us some time & it's probably easier with a few drinks :)
Something tells me if I'm recovered from this throat aids I have at the moment I'll be catching the train in & staying out :(
  • Replies 82
Come along anyway Marco, gotta meet us some time & it's probably easier with a few drinks :dry:
Again, I'm not worried about not drinking, I'm the kinda bloke that finds one or two end up being nine or ten.... Then I get embarassing... :b
Nothing worse than thinking in the morning "WTF, how much f***ing money did I spend, oh crap.... AND WHERE THE F*** ARE MY PANTS!!!"...
Sounds good, I haven't been to the Brisbane yet, I'm a Shed addict.... Don't mind the Deen, Paramount or the 'Stang.... Should be good to try someplace new...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
