  • Replies 82
hey happy bday for yesterday dan! i know im a new member but might come down for a few beers will have to drive home again so will keep that alcohol short :P wont know anyone but looks like i wont be the only one....hopefully :nyaanyaa:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
