and yes you need to check the pressure of the fuel reg. it should be 3 bar base pressure (no vac or boost).
like I posted above 3 bar without vacuum. with vacuum it's 3 bar minus whatever vacuum you have (usually around 0.5bar but it varies).
actually it may be 42 psi, I think it's actually 2.95 bar, but if you can read 2.95 bar on some gauges out there, you have better eyes than me! my point was this guy keeps farken asking the same questions over and over.
honestly mate, I say get the car to a mechanic and get them to sort it out. the last thing you want is to balls it up and damage your car.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
