Ando you want to be like me dont you ?
What 1:18 in a 33GTR................ :sick:
I'll take my 1:13 in a taxi my good friend :sorcerer: :)
AHAHAH lol, but yes in seriousness, i want more grip and power!
Sign up mofo!
  • Replies 107
you will be heaps quicker ando. if you are doing 1:13s at wakefiel, but doing 1:58s at EC either you really love wakefield, or you were getting held back badly with the limiter at EC. 1:13s at wakefield should put you at around a 1:55 or lower at EC. :dry:
you will be heaps quicker ando. if you are doing 1:13s at wakefiel, but doing 1:58s at EC either you really love wakefield, or you were getting held back badly with the limiter. 1:13s at wakefield should put you at around a 1:55 or lower at EC. :rant:
But that doesn't take into account his experiance at either track.
Wheels magazine (May 1991) Kevin Bartlett, in the stock GTR with street rubber rattled off a 1:56sec lap at EC. Just goes to show you what a good driving can do!!!!
you will be heaps quicker ando. if you are doing 1:13s at wakefiel, but doing 1:58s at EC either you really love wakefield, or you were getting held back badly with the limiter at EC. 1:13s at wakefield should put you at around a 1:55 or lower at EC. :rant:
1:13 was my second attempt @ Wakefield and doesnt have the long arse straight like E/C...
1:58 was 1st attempt with the car hitting speed delimiter before the pit entrence down the straight.. so plodding along the straight @ 170km/h would of been costing me a couple of secs me thinks...
All things going well, 2nd time round and speed delimiter removed i am hoping to hit 1:55's or lower....:(
Can't wait!
Proably not of as much interest on a Nissan-oriented forum, but the founder of Spoon Sports will be there, to celebrate their new partnership with Pro Concept.
Edited by scathing
wow... i'm really happy for joshua. i've been going to him since 01, very ealry stage of pro concept..... good old days where you could spend the whole day inside the workshop getting ur car serviced.. going through nismo catalogue, hyper rev mags and talking/smoking with josh :laughing-smiley-014:
hehehehe.... you still can if you don't mind him rushing off mid convo :) or answering a call or having another customer come in.. :D
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
