I've been there six or so times before, and never been fully happy with any of the work. I'm not trying to diss the thread, but if anyone I cared about asked me, i'd advise them not to bother.
Twice on the one system the hangars snapped clean off, another time the hangar was sharp with welding bits that cut through the rubber hooky-thing.
Once when I was there, another customer with a Prelude was having his exhaust changed, and they welded the rear muffler on at an angle (like... 5 degrees counter-clockwise)... the customer pointed it out, so the installer got two long pieces of metal rod and stuck one in each hole of the new twin muffler and then bent one up and one down until the tips roughly lined up with each other.
After that guy left and they were still dicking around with MY car, he turns to me and says something to the effect of "F*&king picky, or what?"
Never went back after that. I tried my luck with Cromer exhaust... but they were about the same with their workmanship.
My mechanic tells me that there isn't any decent exhaust places on the North Shore, and that's why i've never had a reliable exhaust.
Oh well. I'm not saying everyone will get that kind of lack of attention to detail or pride in their work, but I feel it's my duty to share. =-]
come see as at A&B motorsports will we fix you up with any thing you need from an oil change to a full race prepared car and will we make sure you are happy!!!
People should be more careful about what they post on public forums - could ruin a business' reputation/...
Yeah fair enough, I thought it was worth mentioning though as that car is part of the recommendation and the owner of that car hasn't had a good run with them.
It's not so much them he has had a problem with, it is the entire project as a whole...
But as if a 1000+HP Supra is ever going to come together without a hitch...
Trust me, no one (except the owner :)) wants this finished more then i do :D
Well the boys have done it again ! Farkin awesome service and price.
They put the race tranny in - then realised that the flex plate needed modification and GB mounts were busted - so out came the box, fixed everything up good as gold !
Then - put a new Master cylinder/ABS unit on - had a tricky problem with an ABS fault - then no power assistance after the new unit went in. Spent a good while figuring it all out (no one knows how Cosmo's work - but these guys do now)
I was adding up the hours they spent on the car and went there with a pocket full of cash to pay them - ended up being HALF what I expected to pay ! Just awesome !
I just can't be happier with these guys ! I was impressed before - and now I am even more impressed !
And has a huge gash in cylinder 3! :yes:
I dunno, were you working on a car? cause when i went there, there were only 3 people, Andrew being one, the others I haven't met...
One was putting an SR20 into an RA22... what an abomination :)
the other was working on the zorst (i assume) of an S2000...
I was working on my car - but I had to duck home for a bit, so may have missed you . That was Jamie working on the Celica. The S2000 needed a new clutch I think
Fu(king loving my new box !
I dunno, I've met Jamie before, that really didn't look like him :whistling:
Wait, is that Jamies car? I think it's been way too long since I've been there...
Last time i saw it he just hooked up a turbo...
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
