  • Replies 123
Originally posted by whistla
im curious to know who the girl that decided to send what i was written here from me to some admin in mccr?
show your self! PM me now...your low, very low
email me if u cant  [email protected]
id like to know
WTF?
your joking right ???
Dog act... DOG ACT!
IT WAS A GIRL??
lolll
show cat this..
from me..
CAT UR A STUCK UP SELF CENTRE HOEEE
EAT A ***N DIK U SL*TT!!
BAN ME AS LONG AS U WANT ITS NOT GONNA CHANGE THE FACT THAT ur A HOE!!!
ps.. comment on me.. i can rip out something that will tear u apart.. hows luke doin...
hahaah
if u would like to discuss this further feel free to pm me scrag
send her that :P
with love from me :)
dont forget to add the hugs and kisses on the end
Originally posted by MzDfectd
IT WAS A GIRL??
lolll
show cat this..
from me..
hahaah
send her that :P
with love from me :D
and out come the claws...id hate to be in your bad books! i thought inasnt coped a lot!
IT WAS A GIRL??
hahaah
Yeah, I am officially in love with you Ambz. Nothing floats my boat more than a girl who really dishes it up when its called for. I'd call you fiesty but that wouldn't do you justice. Your attidude rocks my world. Next SAU meet, I'm gonna find you and give you the biggest :cuddle: I can. ( before you slap a restraining order on me that is ) :headbang:
OMG!!
laughin soooo hard!!!!!
she pissed me offff badddd
and i dont take too kindly to bimbos whos stupid comments mean shitt all to me.
especially comming from someone that constantly makes dumb ass comments trying to sound like she actually knows something about cars.. only to get laughed at like a moron
some wankerr is posting this link back to her and the mccr admins..
id just like to say
thank you dik hed
ur actually doing me a favour :D
LMAO
:bahaha: :bahaha: :bahaha:
I want pics of that event!
hahah this is so funny for so many reasons
WARDEST ill bake u a cake oki!!!
put me down for one to!
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
    • Ha ha ha, so they stopped the bearings spinning on the one you want, but then decided the crank hub should slip instead 😛   Stick to RB, at least you can work on it yourself. And now it doesn't smell of vapour   Also I still believe there's a chance your new flap doesn't "pop", as even though the engine might breath hard, it has a direct path with no restriction to the inlet, which when on boost should pull a bit of suction for you. If you do get pressure in the catch can id be very intrigued. Time to put a boost gauge on it, and a session at the track, then solid cover your vent and do another session
