  • Replies 273
Posted Images
For shire ppl/st george ppl..
Slim is gonna msg me the time he leaves KK
I reckon there wil be some delays..
So maybe have some lunch at mccas, then come meet up at caltex at heatcote??
So slim- you reckon you will leave KK by 12pm?
get to caltex at heatcote around 12.30-12.40pm
^ this is some indication of the time to be at heatcote for those meeting us there.. cheers
I've decided to come say hi to everyone so I'll be at caltex at 12.30. :D
guys just to confirm
the heathcote caltex is the one just before the M5 bridge on heathcode road?? if so, wat time roughly do you think you will reach this destination?
Edited by Alien
No, Heathcote Caltex is on Princes Highway, Heathcote...it is one km after the Heathcote Rd intesection (where the cruise cars will be coming from) and a before the start of the Sydney-Wollongong freeway at Waterfall.
^ yup this is the last petrol pump!!!
its in the 50 zone!!
So guys drive at 50kms, coz theres always cops there checking speeds..
I reckon they might reach heatcote about 12.30??
So come to heatcote about 12.30 or so..
slim is gonna msg when they leave KK!!
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
