  • Replies 104
Ive never tried it before, but would love to give it a try. I've nowhere to practice so will have to learn on the fly, until now I've only used my handbrake for hill starts and parking, so its going to feel strange.
Someone will have to show me how its done. Oh and how do you remember that course pattern and concentrate on driving as well?
It is going to be a blast guys but remember if there are spots left you will need to be quick
Spots left in what? As Anna said... there is no OPEN for business sign out for the NSW version....
Or is Andrew just in la la land :)
No need to get your nickers in a knot!
I dont wear any..
Just drive around in circles and make your own way...
There are cones that you go around, but I think hitting the cones is fun'er :)
Ok guys calm down.
We haven't opened this event yet so when we do there are plently of spots.
We will be PMing everyone here to notify them when it has opened. No need to get your nickers in a knot!
As per doodz... don't wear any :):D
No need to panic people!!
There will be notice before we open the event and people expressing interest in this thread will be notified!!!
Hopefully wont be long till we know the exact plan and can open the event up for entries! :)
Lol.. Just explained this :D
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
