check the vacuum hose connected to it. the standard gauge has a crappy vacuum hose which gets very brittle when exposed to heat for a long time.
if its an aftermarket gauge then check that the vacuum hose is still connected or hasnt warped somewhere along the line.
if it checks out ok then blow out the hose fitting with a blower vac and try again.
if it doesnt move the needle then its time for a new one.
https://www.sau.com.au/forums/topic/175771-boost-guage/#findComment-3219820
Sometimes you can pull them apart and reseat the gears but it will probably play up again in time.
I had a similar problem and did mine and its still going OK after a few months.
https://www.sau.com.au/forums/topic/175771-boost-guage/#findComment-3219832
nothin wrong with tryin to save a few bucks hot shot..... and ahhh... yeah just fixed it actually..
Well can you please enlighten us with what was wrong?
I'm interested, i think it was probably that the gauge's 12V or earth wires were not connected properly.
https://www.sau.com.au/forums/topic/175771-boost-guage/#findComment-3222025
umm... it was just the vac line that wasnt connected right.. there was a brass t-fitting that had been removed and just had the lines dangling.. so just traced them around to find it... then just pulled the guage apart and played with gears in it... and then when i recconected it and so it was back to zero and workin fine... soo yerr.. thanks for the help guys
https://www.sau.com.au/forums/topic/175771-boost-guage/#findComment-3222054
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
