Hey guys,
Just bought the white ones, I'll put them in the '93 four door, so put my name down for the black ones and send me the details for payment. Thanx vidak
Added you to the list, PM on its way :D
  • Replies 190
i would be interested but i have the NA gts4 dash i will need to modify it myself for slip light and AWD light would you know apart from that my speedo oil pressure fuel guage all looks the same can you confirm with someone please
Hey mate, i'll ask Amec for you, but I think he'll say the same thing that he said to the GTS (non turbo guys). If you buy 1 and try to fit and calibrate it, and it doesn't work, send it back to him and he'll refund your money.
ah ok so dont drill any holes if i suspect it wont fit cause obviously he wont refund if ive butchered it
I've sent him a PM, so i'll let you know as soon as he replies. As for that question, i definitely wouldn't drill any holes in it. Put it in and try the recalibration..if that all works then drill away...if not take it out carefully and send it back and you should be right :D
Hopefully it works fine though and you can keep it in your car :)
yeah i just went and took a happy snap as i thought everything the same minus the boost gauge and addition of slip and AWD to which i could get a slip and AWD vinyl made up
looks identical except for the lack of boost gauge and the slip 4wd lights mate....considering all of those things are part of the tacho, I think you'd be fine if you left your stock tacho in place and replaced all the other faces with the ones from this kit :D
Let me know if you want to be put on the list and i'll give you the payment details.
yeah Johnny put me on the list please
do you know what light mod this is
Amec said same deal for you as the GTS boys...try it and if it doesn't work, send it back un damaged for a refund...I'll add you to the list. Check your PM for payment details :ninja:
As for the lights, As far as I'm aware thats just the standard globes, not even LED's :yes:
list updated ..
still waiting on payments from 6 people on the list....if you haven't paid and are on the list, can you please let me know if you still want to be in the group buy
The following people still have not paid
DazWah
JeaneenGTST
SK8N33
R334door(s2)
DaGr81
R334door(s2) has already told me he's paying today so thats fine, but the others, if you're no longer interested can you please let us know so everyone else on the list knows where they stand. if you are still interested can you please pay ASAP so that we can get the speedos made, and everyone will get theirs sooner!
cheers
hey all,
would really like one of these kits. just a few queires though, do they definately work for auto's, are they only $100? and how would i go about paying for it.. cheers!
ill have a try at answering, correct me if im wrong jar or amec
yes they are onbly $100
they are just vinyls so they will work with auto as long as it is the same layout
i am 95% sure the solder point will be the same on an auto to make it a 300km speedo instead of 180
payment can be made by direct deposit
just want to get mine soon lol
hey all,
thanks tek 01..spot on :rolleyes:
Mate there's a photo of the kit fitted to an auto cluster on the first page, so it definitely fits. I'm almost certain it works as I haven't heard otherwise, but like a few other people in the group buy, with non turbo skylines, Amec will refund you if it doesn't work on your car and you return it un damaged.
Let me know if you want to get in on the group buy and i'll PM you with the bank account details to deposit into :thumbsup:
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
