Want the Fast and Furious look without the dramas of modifying your car??? Well this is the car for you, it's already done!!!
For sale 1993 180sx
RED in colour
Sr20 Turbo Manual
Five Puck Brass Button Clutch (Brand New brand new fitted 2 weeks ago)
R33 front brake conversion with braided brake lines
Cusco Rear Coil Overs
Lowered Front King Springs (Brand New)
16x8 inch White Enkei wheels with near new tyres
Full three-inch exhaust from the dump pipe back featuring stainless X-Force muffler (Brand New fitted 2 weeks ago) with five-inch tip mounted drift style
Gtr Fuel Pump
M’s K&N air filter (serviced yesterday)
Malpassi Rising Rate Fuel Pressure Regulator (not Fitted)
Nismo Rear Strut Brace
Cusco Front Strut Brace
Cusco Master Cylinder Flex Brace
Cusco Mechanical Limited Slip Diff
Greddy Blow off Valve
HKS electronic boost gauge
HKS Turbo timer
Nardi Steering Wheel
Razo Pedals and gear knob
Go Fast Bits bleed valve
B-Wing, full dorifto style!!!
Brand new Pioneer head unit
Brand new Pioneer 6 inch three way front speakers
Brand new Pioneer 12-inch sub in carpeted box
Stinger Cabling
Custom 50JAP number plates
Custom rice stickers
Registered until the 10th month with road worthy
Very clean straight car with brand new paint. I am selling due to loss of job
Asking Price $18,000
For more information please do not hesitate to call me on 0421440234
https://www.sau.com.au/forums/topic/17592-fs-1993-180sx/
Hey Ninja dude i was lucky enough to get nearly all of the gear with my car thats why i paid more for it in the first place. If you want you could drop Garth at Kaos Racing in Rockhampton on 0749228888 he helped me out with the new parts that i've added
the car is in rockhampton and just for interest sakes i ran my car on the strip yesterday a 14.1 on standard boost isn't too bad unfortunatly the dyno shop that tuned my car kinda plugged a few of the vacum hoses on the wrong way and it was confusing the hell out of my computer. Didn't figure that out until late in the day but now every thing is sweet!!!!!!!
https://www.sau.com.au/forums/topic/17592-fs-1993-180sx/#findComment-396008
Gee, sounds like they really know what they're doing :)
https://www.sau.com.au/forums/topic/17592-fs-1993-180sx/#findComment-396374
well now its up to you guys name your prices and i'll get back to you. basically i am going to loose me licence as well soon which sucks so really won't have much of a use for it so im guessing around the $16,000 mark would probably suffice a reasonable price
https://www.sau.com.au/forums/topic/17592-fs-1993-180sx/#findComment-400626
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
