G'Day Guys. Some of the blokes on the forum are interested in a Skyline cruise this coming weekend. No surprise there eh!
WHEN: 12PM SUNDAY MIDDAY - July 28th
WHERE: HOMEBUSH CAR PARK 6C
CRUISE: MEET AND HEAD TO THE NORTHERN BEACHES VIA THE CITY
Would be great to get a good few Skyliners for this one! I'll try and get a few of the R31 crew to come.
Who's in?
Cheers, MARK
PS - It'll be my last weekend of driving for 3 months. I gotta hand in my licence to RTA on Tuesday :D
https://www.sau.com.au/forums/topic/1761-sydney-cruise-sunday-july-28th/
  • Replies 45
2nd half of nasho comes to mind.
if the weather is good i'd prefer to go for a coast drive or something rather than city. that's just me though.
ask neil (ndr) about the second half of nasho. he took a few of there late one night and it's an awsome drive. it's called 'something' dam. sorry but i forget what it is exactly.
I ain't going anywhere near Brighton/La Perouse/South with a big group of cars... It's just asking for trouble...
I'm going to have to put my vote in for a drive up to the Northern Beaches instead...
Andrew. :uh-huh:
Palm beach is a top destination. Parking shouldn't be too bad in the middle of winter either. There's always Whale, Avalon, Bilgola, Newport, Mona Vale or the boat ramp carpark at Bayview as well.
I'll probably meet up with you guys at the final destination. See how it goes.:cool:
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
