SAU Caps & Beanies... just made a deal, any1 want one?
Just made a deal with a manufacturer that should see us all wearing an SAU cap for about $20 each.
Its made in the same factory as ecko (the gangsta clothes label with the rhino logo) caps.
The design of the cap is as follows: Elastic base rim (no straps at the back) 12x16 cotton twill sandwich cap with curved visor.
Here are the options:
  • skylinesaustralia.com in a marquee around the base of the cap.
  • big f**koff emblem in the middle on the front
  • any other design that will fit on the cap
Please suggest some designs which I'll then implement and send to the manufacturer.
Here's the catch. We have to purchase 100 of the fvuckers coz their minimum run is 100. (theoretically 102, but they'll give it to us for the price of 100).
please vote "I will buy" if you want one. Once this tally hits 100, then I will make arrangements for payments and then place the order.
Part of the money raised will go to the running of the forums. All purchases from VIC forum goers will get a certain percentage donated to the running of the VIC club. Similar arrangements can be made for other states.
I have attached the ecko cap that they manufacture as a reference.
UPDATE
OK here's what we have so far, we have about 80 odd requests for caps and beanies, so I'll put the order in, now we have to figure out what design we want on the caps/beanies. TO keep it simple we might just go with the same design on both.
here's a mock up of the cap that I made, any improvements/suggestions will be appreciated.
  • Replies 246
ye i'd buy one.
but when u say they make a minimum run of 100 - does that 100 of exactly the same colour/design? coz then we'd all be like wearing exactly the same hat. and at a meet that'd look weird. may as well all wear uniforms.
but yeh, put me down for one.
omg... caps ppl... I'll make inquiries about beanies tho... dunno if they make em, but they make all the ecko head gear and ecko has beanies... will find out
Put me down for a cap and a beanie too!
What about using the typical "SAU" with the lights on either side. I know we have used this logo alot, but it says what we are about.
The "skylinesaustralia.com in a marquee around the base of the cap", is also a good idea.
How about getting the Model of our cars at the back of the cap. eg: 33 or R33.
This is a mad idea, thanks Funky!
Don't think we can get personalised ones for each type of ca; unfortunately it has to be one design only (otherwise I'll have to get 200). Don't know what the go with the designs for the beenie and the caps are as they're clearly gonna be 2 different things.
Here's 3 designs we have atm:
A monogram block... r34 tailights with SAU under it
A block made up of the url cut up into chunks
A straight line url, probably best suited for around the base.
Any other ideas?
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
