SAU Caps & Beanies... just made a deal, any1 want one?
  • Replies 246
OK, here we go guys, I've made a final design of the cap, from popular requests etc. Let me know if you guys want anything changed. I'll make up a new thread where you can state what colour and quantity you want, and I'll get cracking on getting those samples before we send off for the motherload.
As for the beenies, its pretty straightforward, I'll whip that up tomorrow.
Again, tell me if you need anything changed before I send this off to the manufacturer
ok ok, I think you can figure out that I jus placed the last graphic on top of the cap and didn't really put it on the 3d model... so dun giv me no shit 4 it. but yeah, that's how I picture it'll look.
If you guys want, I can get em to put the logo and text on the side onto a piece of cloth (sorta like a tag) and stitch it onto the cap, so if you don't like it you can remove it.
If you're wondering why the emblem looks different to yours, then you probably drive an R33 or a R32. The emblem is off the R34 manual.
I like it Funky.
I'll still have a hat and a beanie exactly like that please.
Can you send me the jpgs to [email protected] as I can't save pics at work andI'll run the design past Nissan Aus.
Great work mate,
Dan.
Design looks good Funky. . . Great job
But does it seem a bit crowded with 3 items on it?
I think maybe you can replace the SAU with the Skyline Australia from the side and just have the front and the back.
Either way I still want one haha and one beanie.
Lets get them!!
:D
Cheers
Aaron
REVERSE IT SO THE LIGHTS ARE ON THE BACK!
a) it makes more sense as cars tail lights are on the back... or tail... funnily enough...
B) it looks teh ghey
I still want one of each! :rolleyes:
Great work!!
Just a question, no critasism intended; Is the text on the side of the cap going to be stretched wider? This will make the web site stand out a little more. Either way a GREAT piece of work.
nah, a lot of people told me they don't want the website in large print cos it looks very nerdy, so basically its gonna be like a tag size thing on the side.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
