Ok ive got a gts series 2 r33....its completely stock.. i want to get an exhaust put on that will sound loud and nice n give it that extra kw...
Iv seen on justjap.com
HKS hi power exhaust-catbacks for $900..so thats a muffler and all included yeah??
or
Should i buy x force cannon muffler 3 inch $195
x force 3 inch high flow cat $199
and get custom 2.5inch piping done at a local mechanic or whatever????
which would be the best option to go with?? any help appreciated. thanks
https://www.sau.com.au/forums/topic/176320-exhuast-help-plzzzwhat-to-do/
Hi flow cat - Power
Mandrel bent - Power
a good cat back - Power
Muffler - +10 on wanker scale and louder..
and yes.. mufflers are included on cat backs..
Personally.. go the second of your options.. i.e. Hi flow cat (may now have MASSIVE benefits on a low power NA car).. mandrel bent 2.5" and a muffler.. this it would suite your wants best
dont know much about Xforce products.. or their quality..
Best to do research.. Save and get good quality (like coby) headers.. a full manderl bent 2.25 - 2.5" exhaust.. cat.. and muffler..
  • 1 year later...
didn't want to start another new thread on a worn out topic so i thought i'd re-use this one
i've just had a new intake and full exhaust put on my car. picked it up this morning from my mate after i've come back from a weeks holiday.
driving the car home 20mins has left my head feeling numb and ears ringing from the loudness and the drone.
the full exhaust comprising of HPC Coby's, high flow cat, custom mandrel SS 2.5" exhaust, oval muffler with twin tips for factory look. I'm seriously regretting it at the moment and want my factory exhaust back on.
it's been suggested to me to put an oval resonator in but i'm not sure if that alone will be enough to quieten the noise and remove the drone. i'm also thinking a new muffler as well.
so i seeking some help from those who have actually had this dilemma and what did you do to fix it?
Reggie.
Ive got a 2.5" catback mandrel bent exhaust custom made.
cant even hear it on idle, but it begins to roar after 3000rpm.
i LOVE it because people are astounded about the difference between how quiet it is during idle, and how nice the grunt is at high rpm.
going to get a new high flow cat soon...not sure If i want to buy Xforce though...
Reggie ive got a resonator on mine, works a treat.
p.s. mine droned quite a bit for a few weeks....so give it sometime and see if it quietens down after a while...
When I was talking to one of the guys at Rob Bliss Exhaust a few months back, he said that oval barrel twin tip on an N/A will drone and they haven't been able to get rid of that drone. Seems like it's a characteristic of that muffler.
I was thinking of going for the twin tip factory look as well when I end up doing my exhaust, but the noise I guess will offset that factory like side of it. You could always get a factory twin tip of a GTR, that should flow plenty for an N/A and keep things quieter.
when i first put the 2" system on the SSS i only had a lukey muffler on the rear and it was noisey as hell but sounded great. the guys fitting it got me to take it for a spin round the block to see if i wanted to quiten it down. i took it for a spin, and as much as i liked the sound i knew that mr policeman would bend me over and insert his nightstick into a certain orrifice if i left it that loud, and also on trips it would piss me off, so we put eith a 12 or 14" resonator (hotdog style) in the centre and it made it much better. although it did lose a bit of bark.
so a resonator alone won't be enough to tone down my exhaust volume and drone?
i.e. get it under the legal db level?
i found a hot dog keeps it down nuff long as ya aint got a cannon on the back lol, though it does drone quiet abit but tis bearable :P... mild steel defo ova stainless tho!!! hahaha less ya want it 2 sound like a tin can
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
