My question is more on the way its fitted.. If it needs a pin throgh it, to be sure it wont spin on the crank.
Now its mounted this way: crank was cold shrunk, collar heated to 100 degress, both parts degreesed, special glue, VERY strong and will hold up to 150 degrees, still needed 2 tons to be pressed on. (No I did not press 2 tons down on entire crank, a metal bar was fitted just down under the first counter weight.)
Question is, do you think it will stay on and not spin round the crank. I dont know how much force there is trying to twist it around the crank.... How hard the oil pump is to drive..?
https://www.sau.com.au/forums/topic/176327-is-this-okay/
Rule of thumb from an old engineer when they used to press on drive sprockets. A 2 thou tolerence fit on a 1 inch pipe 1 inch wide will drive 40hp.
Thats an interesting rule of thumb when you think about it, as HP doesnt have anything to do with it does it!
https://www.sau.com.au/forums/topic/176327-is-this-okay/#findComment-3226313
It's to do with torque and how much pressure is being created outwards on the outer surface with the interference fit.
https://www.sau.com.au/forums/topic/176327-is-this-okay/#findComment-3226340
    • I know -_- Oddly enough I went to a car show this weekend and not a single person made any mention of Nitrous... I did have to argue with a know it all that was convinced I had an RB26 head with HKS V-Cam as opposed to a regular VCT RB25 head, but what do I know. I think my HKS oil cap was throwing him off.
    • That seems like a lot more work than just using a second jack under a front tow hook to raise it enough to get another jack under it.
    • They're wonderful when only used to lift your car up an inch so a real jack fits under your front lip. Besides that, I've only ever used them on the side of the road.  We call them widow makers here.  Unfortunately, like I mentioned in another post, ramps are not an option for me due to generally working on my car once my kids are asleep. Cold starts, 4" exhaust and sleep rarely go well together. I honestly find using ramps a hell of a lot more work than what I'm currently doing anyways.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
