My question is more on the way its fitted.. If it needs a pin throgh it, to be sure it wont spin on the crank.
Now its mounted this way: crank was cold shrunk, collar heated to 100 degress, both parts degreesed, special glue, VERY strong and will hold up to 150 degrees, still needed 2 tons to be pressed on. (No I did not press 2 tons down on entire crank, a metal bar was fitted just down under the first counter weight.)
Question is, do you think it will stay on and not spin round the crank. I dont know how much force there is trying to twist it around the crank.... How hard the oil pump is to drive..?
https://www.sau.com.au/forums/topic/176327-is-this-okay/
Rule of thumb from an old engineer when they used to press on drive sprockets. A 2 thou tolerence fit on a 1 inch pipe 1 inch wide will drive 40hp.
Thats an interesting rule of thumb when you think about it, as HP doesnt have anything to do with it does it!
https://www.sau.com.au/forums/topic/176327-is-this-okay/#findComment-3226313
It's to do with torque and how much pressure is being created outwards on the outer surface with the interference fit.
https://www.sau.com.au/forums/topic/176327-is-this-okay/#findComment-3226340
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
