I bought my car from a dealer + when he explained the security in the car he said he'd left the stock immobiliser in + added the proximity sensor immobiliser as well, giving me 2 different immobiliser setups...
If I don't hit the 'unlock' button on my key remote, the car won't start. It'll keep turning over, but refuses to start. It self arms this as well. If I turn my engine off + don't lock the car, I still need to hit the unlock button to disable the security + start my car.
And of course if the proximity sensor isn't next to the ignition, the car won't start.
https://www.sau.com.au/forums/topic/176463-alarm/page/2/#findComment-3611471
So the factory alarm is supposed to be stripped as part of compliance? If so, what is the little fob thing on the key chain for, and also the sensor looking things on the dash? Do they do anything?
who did the compliance on it? if ISASO then it was me that removed it. I've had 3 of them disable 3 cars on me so when I do the compliance immobiliser them they come out. its not factory anyway. they are dealer fitted and some of them are barely fitted. most are in with scotch locks and they are ALWAYS loose.
the black tag on your keyring(autowatch badged) is the Immobilser. two pt std issue. the round thing below the boot release switch that looks like something pushes into it does nothing.
https://www.sau.com.au/forums/topic/176463-alarm/page/2/#findComment-3612926
hey guys,
just a quick note about the adr82/00.. if the vehicle is fitted with a factory immobiliser there is a way around having to replace it
dotars recognise the ULC-S338/98 which is the canadian standard for immobilisers (all vehicles in canada must be fitted with an immobiliser whether stock or aftermarket)..
The ULC-S338/98 does mention the Infiniti v35 so all you need to do is prove to dotars that the v35 and g35 have the same immobiliser (which you can grab of the Nissan Fast system)
We have been using this evidence for most vics and dotars have never questioned it...
hope this helps
cheers,
k
https://www.sau.com.au/forums/topic/176463-alarm/page/2/#findComment-3613715
I'll apologise in advance for my lack of knowledge both in this area, and cars in general. So I have the keychain thing, the two sensors on the dash, a small light just under the clock that flashes once the keys out of the ignition, and a red light labelled "Security" to the right of the steering wheel. Do I have an immobilisor or an alarm, and if so, how can they be activated?
Also, I got the car from a dealer in Sydney who do their own compliance.
Sorry again, this isn't really my thing! If I was in Brisbane, I'd be over seeing Chris Rogers already!
https://www.sau.com.au/forums/topic/176463-alarm/page/2/#findComment-3615516
word of advice- leave it all alone. if you activate it by mistake (IF it works- see other post ) then you have stranded yourself. if you have the nissan branded tag press it into the slot below the steering column. that will activate the dealer fitted alarm. the OE one 1s self triggered. the autowatch one is the same.
https://www.sau.com.au/forums/topic/176463-alarm/page/2/#findComment-3615654
  • 4 years later...
any of the alberts stores. see cannington and speak to pete. get them to toss a autowatch 446 P in it.
Hi Chris,anyone you could recommend in Melbourne?
Edited by rawzz_v35
https://www.sau.com.au/forums/topic/176463-alarm/page/2/#findComment-6401388
ok so stopped down at Alberts today. They are going to put in a slightly different system that runs off my car key. $550 installed.
Sound about right? I asked for the Autowatch 446 Premium, but Pete was talking something slightly different.
Once its booked in, I'll let you know exactly what it is :)
Thanks again!
https://www.sau.com.au/forums/topic/176463-alarm/page/2/#findComment-6405179
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
