Bee R make a rev limiter and launch controller that you can install in cabin.
It basically allows you to set your desired rev limit. Unlike factory rev limiters which cut fuel, this one cuts ignition, so fuel still goes through.
When they hit the hot turbo they ignite and u can get your flames comming out of the exhaust like the movie.
However it will drastically shorten the lifespan of your turbo.
  • Replies 121
Originally posted by Zensoku
but that is what the "ricey arming red missile switch" is for!:bahaha:
Maaaan I had that shit on my strawberry face 180 back in the day as a kill switch for my amp. Back then the only place you could get it was at Jaycar, and it fitted a corresponding PSTN switch... thought I was pioneering shit, until at autosalon my car was right nex to sum otha f00 who had done the same thing... so naturally I had to remove it...
Now every shop carries it. :P
BTW kidd... here's an interview with Lieberman... it belongs to Hiro from Motorex.
http://www.nissanperformancemag.com/march03/lieberman/
NPM: Was the new color scheme strictly chosen for use in the movie "2 Fast 2 Furious" the sequel to "The Fast and the Furious"?
As it will appear in in the upcoming movie "2 Fast 2 Furious"
C.L.: Yes, The car is silver in the movie. It looked awful, so we just got done painting it back to blue. Why anyone would want to put SS Camaro stripes on a JDM Skyline is beyond me, but the guy designing the graphics (Keith Burns, Prod Designer) hates cars and generally needs his head examined when it comes to car accessorization, just my opinion.
NPM: Sounds as though you weren't too happy with their choice and couldn't wait to get it back to the original look afterwards.
C.L.: The gray/blue thing was ok with me. But the aforementioned clueless designer covered my carbon fiber nitrous bottles with chrome vinyl…it was the first thing I changed when I got the car back. In fact, this dude covered every carbon fiber surface with colored vinyl. As you can tell, I'm not very happy about his choices
Hahaha spoken like a tru Skyline owner :P
watched the movie and was also eager to find out what fuel they run. as for those flame thrower kits i had one on my old car and it was the spark plug typr but only ignited the fuel on with the switch was pressed and also caused the ignition to die ( like doing a key banger with out the stress) as for the REAL car comment if you watch a top fuel drag car they have continuos flame for the hole time they drag. aren't they real cars NZM.031
my skyline can pop flames and nearly all the turbo cars i know can pop flames run a different fuel like menthanol or high grade av gas and you'll get more flames
Originally posted by RedLineGTR
the non funny thing would be if someone had it setup like that and one of his mates didnt know imagine if he pressed them...the plenum would go pop..
Yes, I've lost count of the number of plenums I've heard of going 'pop' from nitrous use. Also imagine what would happen when the car finally rolled to a stop.. why at least 500 porcupines would then drag the owner and his friend from the car and beat them senseless. Because as we all know this is what happens when you use too much NOS. Just like parts of the floor falling off really isn't it, you know -- the excess NOS finds it's way to the seam welds and unwelds them.
Zensoku,
You should put little NOS stickers on the horn buttons and charge twice as much for the steering wheels I reckon.
Like it isn't already happening in Sydney and the Gold Coast.. its on all the Wannabe rice boys shopping lists...
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
