RB25 tappet covers $100
GReddy Profec B Spec 2 boost controller $300 - SOLD
6Boost inlet manifold $350
Turbo similar to gt3037 58ml front wheel .86 rear internally gated 550 hp with standard manifold and dump pipe $1250 neg
Standard Cluster Series 1 $100
Standard Blinkers $20
intercooler, piping, intake, pod filter and catch can $500
Also have standard R33 Interior from S1 front and back seats, 4 door trims. no pics yet. $350
Can post some items. All items located in Wollongong NSW.
PH Mick: 0411447639
Edited by MI51LE
interested in the plenum, pics on car, what sort of gains, what throttle body fits it etc etc
hey i have never used the plenum so i couldnt tell you any gains, i bolts straight up to the bottom half of the standard manifold
and it uses a xf throttle body
PM SENT
What is the actual brand and model of the turbo?
How many Km's have you put on it?
How much boost has been run through it?
Any shaft play or other problems?
the turbo is pretty much sold
its a garrett not sure on the model
its done about 20000k's i had it checked out today at turbologic in wollongong and was told its in good working condition
  • 3 weeks later...
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
