hi guys
on the weekend i did a DIY on my r34 gtt stock bov
we cut a coke can into the shape of the BOV as a gasket to block off airflow causing it to flutter but now it is back firing pritty regularly
y is it back firing so much ?
and how much damage am i causing to the turbo?
thank u =)
Edited by skylinesrus
https://www.sau.com.au/forums/topic/176614-flutter/
  • Replies 46
hi guys
thank u =)
your car will also stall.
I did the coke can thing and undid it. Its crap. Get a HKS SSQV if you want flutter.
https://www.sau.com.au/forums/topic/176614-flutter/#findComment-3230177
The afm is expecting air (from plum back bov) to be returned to the air flow, so when you stop that air being plummed back into the air flow the air flow metre doesnt know this and just assumes everything is normal, hence thinking there is more air there than there really is, therefore keeping the same amount of fuel for less air, causing it to run rich. hope that made sence
https://www.sau.com.au/forums/topic/176614-flutter/#findComment-3230202
So if u put the afm in the cooler piping do you rekkin it would run beta?
https://www.sau.com.au/forums/topic/176614-flutter/#findComment-3230737
not too sure but the thing is...people have done this but the AFM isn't designed to be placed under pressure, its just plastic, and excess heat to this plastic can cause it to become brital. The afm relies on an accurate reading of resistance measured by a very thin wire. Any excess heat to this could cause improper readings, hence different air/fuel ratio....probably wouldnt be f**k all but there's no point just for a flutter and bad economy.
https://www.sau.com.au/forums/topic/176614-flutter/#findComment-3230770
LOL
it works... but wouldn't recommend it on a r33 with the ceramic wheels..
blew mine out my exaust pipe and also straight into the intercooler..
i don't see any issue with a steel wheel type turbo
edit: i have fixed this up cos people can't seem to understand wtf i was saying...
https://www.sau.com.au/forums/topic/176614-flutter/#findComment-3231400
LOL
blew mine out my exaust pipe and straight into the intercooler..
Err how is that possible? Is your exhaust connected to your intercooler? :P
https://www.sau.com.au/forums/topic/176614-flutter/#findComment-3231517
LOL
:laughing-smiley-014:
Luckily it didn't go the other way and end up in your sump hey? or even worse, in the flux capacitor.
https://www.sau.com.au/forums/topic/176614-flutter/#findComment-3231575
aah.. school holidays :P
if and I stress IF .. your serious about this make sure your aware of the possible damage it might do
also if you REALLY want to do this .. least give the 34 a bit of respect and cut a bit of 3mm Ally plate and paint it black .
on a LOT of cars you will get flutter if you back off on low revs -
at full throttle the BOV is designed to stop air " ramming up against " the throttle body and traveling back past the turbo wheel
https://www.sau.com.au/forums/topic/176614-flutter/#findComment-3231590
    • Hi guys, thanks for the replies.  I will have to wait till summer to test properly, but it short cycles both when heating and cooling. I’ve ordered a new internal temp sensor that sits under the vent in the steering wheel also, GTSBOY, I have an Apexi FC ecu, I’m assuming I won’t be able to diagnose or would it still work? Could the ecu be causing the problem??   the pressure switch is quite cheap I will get a new one and try it out, hopefully it doesn’t require purging the refrigerant again?
    • Do you know what size restrictor? Just flushed it with the Prestone flush & then water numerous times until the water ran clear, still looks rusted & will no doubt cause trouble later.
    • you can enter your VIN (the original, japanese one) here to find the correct part#: https://www.amayama.com/en/genuine-catalogs/nissan however, after all this time it is more likely to be a wiring issue than the sender
    • no, it was the same here, just flurries but no need to get the toboggan out....but it is exactly the sort of days where its good to have some inside jobs on the list. Speaking of which the fuga is driving properly after 2 1/2 years.....but that is a whole other thread
    • And yes, put in the restrictor while you are there; a standard engine is fine with a little less oil and you are less likely to run out of oil if you have sustained high revs for any reason eg visit a track one day. How did you clean the cooling system
