Everyone that has a 2003 coupe might experience this.
I started my car this morning usually let it idle for 5 mins to warm up.
When i took off doing under 10km/h the car changed from 1st to second. I got this grinding/ recoil noise from the front. After that it didnt happened. I stopped and tried it again nothing even when changing gears on the highway.
Second time started it up after 5 hours put it into DRIVE, drove under 10km/h changed 1st to 2nd same thing grind for a split second then nothing.
Im a member of the G35 club in the USA, asked them questions and there were even threads regarding this matter. Apparently its the ABS initialising and doing a check. Some of the guys own 05, 06 & 07 models. They said it happened to theirs after only having 1000km/h on the clock. So it must be the ABS checking. There are probably a dozen threads on this problem and all the guys said its normal. Anyone experiencing this?
Yep, got the same thing in my 05 Coupe.
Was a bit worried the first time I heard it, but then as you said noticed it was only doing it when you first drive after start up, so I assumed, don't laugh, it was some sort of pressurising of the brake fluid, in the lines.
Good to know it's normal :-)
Yeh, That is ABS test or inital something.
If you are luck put your food on break pad at the same time (Just like me when i approch the garage door ) you will fell the pad same same respond as ABS break kick into in hard breaks.
That is common take it easy.
Coming to think of it and describing the exact noise i wound't say its a grinding noise. Think of a spring recoiling thats what it sounds like.
Yep normal it is even mentioned in the owners manual that I got with my car. It was printed by the company that complied the car.
I don't experience that.... hmmm. Maybe thats cos I have reset my ECU cos previously all warning lights used to come up... Since then, I've experienced little any electronic intrusion compared to before when my VDC used to cut in.
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
