  • Replies 843
Posted Images
lol smartass... i shoulda just been happy with what i had with the 25/30 but no i had to go for more...2 years later hmmmmm lol
How far off is it, Ben? What's left to do? I can't wait to see what Marky-Mark can do with your tune :P
Joe at Profab has made the 4" dump pipe for me and fitted the O2 sensor, plumbed the gate back and is remaking the cooler pipes (some were still made of steel) and what was there wouldn't work with the front facing plenum and different location of the turbo. Joe also modified the power steering pump to space the pulley forward in the bracket. Here's some pics.
Ben, the race is on! Who will be ready first?
Mine has no ...suspension inc. top arms, lower arms, coilovers, caster rods etc (Dave borrowed all that for Superlap)
...race bucket and harness (Dave borrowed that too)
...HKS igniter (Dave again)
...Rear diff (just had it modified and rebuilt)
...Transfer case (currently having it modified and rebuilt)
...Turbo kit (sold the lowies and waiting on something special to arrive by courier)
...Head (its off so i can fit a slightly thicker gasket to lower the compression to run massive boost)
...Gearbox (its sold and PPG straight cut dogbox platinum model to be fitted)
...clutch (going to qld to be reco'd by NPC)
...Tune (Autronic in and tuned for pump not for race fuel)
...Pipework (new turbo to intercooler pipes to be done by Hypertune)
...Parachute (needed with the new set-up)
all this and i still think ill be racing before you will be :D
Cooler pipes finished today and car at auto-elecs getting oil pressure warning light and AFR meter wired. Just have to run a line to the ECU's MAP sensor and then we'll fill it with fluids and fire it up.
You've got a bet, Paulie! One shiny, silver 20-cent piece and a cold beverage sound fair?
Game?
:D
lol scotty i think ur on the money..honestly... hahaha
like i mentioned still few things to go adrian, leigh HAS my car (whoohoo) doin the exhaust and few other little bits n pieces, then dump goes off to be coated, while thats gettin done we will fit the rear end and do the wiring, ready to get tuned...wont have it for jambo i doubt it but ah well...maybe if they kept it to september that was so much better...
haha i wont bet against pauly that his will be ready 1st, i can see it happening lol...thats all the funds adrian has atm to bet
ben...
ben...
Too right, Ben. AND I had to borrow the 20c to front the bet!!
lol dont worry im in same boat hahahah, we're very smart lol...
i got mine for u too ;-) haha bunch of poofs... rightio i can get those stickers done pretty much whenever so yeh all good
Sweet. Don't forget the small goods platter for Jambo and the support van!!!
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
