  • Replies 843
Posted Images
Stuart, more rice for the whale! Need an idea on where to fit the sender though. Thoughts?
:D
nothing rice about using good quality American gauges.
I fail to see why a gauge requires the need for an "opening and closing ceremony"....its not the bloody olympics!
Edited by DiRTgarage
the thermostat housing is on the side of engine underneith intake manifold, so it wont be going there, besides it has to go before the thermostat, not after. id say just swap it out with standard guage sender, as it would be gay to run two temp guages, full auto salon temp tacho style.
Top Hose with one of those adapter thingos......or just tap the thermostat housing
  • 3 weeks later...
No updates in more than a month. Goes in for a tune on Saturday and will post results.
Dropped the oil filters yesterday and found stuff-all of any interest. That was pretty positive. Also discovered the best thing NOT to wear when working on a car is jewelery/watch.
I had the fuse cover off the fuse/relay box on the driver's side and was tightening the main oil filter line up when my watch touched both the positive terminal on the battery and the throttle body. Trouble was, my hand was stuck (I had put some effort into wedging it in there to get to the fittings) and it took several goes and lots of swearing to get it out. All the while big sparks were flying and my arm was burning.
I tore my watch off only to realise that the back of it was burning my other hand so i threw it on the ground and went to run cold water on my wrist. It looked okay till about 20 mins later.
On a brighter note, my TG Live tickets arrived. YAY!
TG Live iss expensive.....boooo
yuk on the burn. looks dirt.
Picked up four of these little farkers for an absolute steal thanks to Pauly. Don't have to drive 'round on the drag radials now.
You're lucky I didn't walk out with them the other day......I seen them on my way out but they are just 10mm too wide for the golf :D
don't forget to do the deal with Lee...get onto him...he said he'd have it done by now.
You need to get onto him and chase it, mate. I'm happy to pick it up and send it up to you though.
The boss bought some tyres from Ozzy (that your mate referred him to) so there was no money to be made on them. :(
Even worse, they didn't fit on the front end so he bought two sets! :)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
