so i died a little on the inside earlier this week as my speedo hit the precious 100,000k mark on the gtr :banana: . just wondering what exactly needs to be carried out for the service? timing belt has already been changed, but i'm assuming ALL fluids, plugs, filters and what else? cheers guys.
https://www.sau.com.au/forums/topic/177473-100000k-service/
so i died a little on the inside earlier this week as my speedo hit the precious 100,000k mark on the gtr :) . just wondering what exactly needs to be carried out for the service? timing belt has already been changed, but i'm assuming ALL fluids, plugs, filters and what else? cheers guys.
I will try and list all that i remember from when i did the 100k service on my 32 GTR:
Idler and Tensioner bearings
All belts (aircon, water pump, power steering)
Coolant flush and refill
engine oil and filter
water pump
fuel filter
radiator hoses, top & bottom
Diff oils
Transfer case fluid (atf)
Gearbox oil
Timing belt - even if it was 'done' when you bought the car, do it again!
Spark plugs
There are probably a few things i have forgotten, I will add them if i remember them.
BTW - i have all the above part numbers and where to get them from if you are interested.
Cheers!
Dan :D
https://www.sau.com.au/forums/topic/177473-100000k-service/#findComment-3241812
I just did mine bought a kit from Kudos motorsports and got it all done. For now ive done
Timing belt
water pump
idler and tensioner bearings
Seals
Cooling system flush and refill
Mechanic then just recommended changing radiator hoses and thermostat but all seems fine for now so will be doing it later :thumbsup:
https://www.sau.com.au/forums/topic/177473-100000k-service/#findComment-3243645
By all means replace the waterpump and idlers whilst the timing belt is off but when it comes to fan belts etc replace them as nessisary not becuase its a 100K service. If cam seals are not leaking dont touch them because chances are they will leak afterwards!! If itss aint broke dont fix it!!
Get all sorts of stupid things suggested daily but really treat it like a regular service with a timing belt. Replace worn items and keep driving.
https://www.sau.com.au/forums/topic/177473-100000k-service/#findComment-3245100
4 days from kudos?? I got mine in 2 days first thing in the morning at 7am from the courier. Top stuff there everything you need. top bloke. I changed seals because cant be stuffed paying money later on labour costs to change seals and after speaking to nissan they recommended changing seals also. So as they say aswell precaution is better than a cure.
https://www.sau.com.au/forums/topic/177473-100000k-service/#findComment-3246335
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
