Just need to group the leads together, so the coils fire 1&6, 5&2, 3&4. Now that i think about it the igniter should be fine, as the bigger coils will have higher internal resistance, therefore draw less current, althouhg they would ideally want to draw it for longer(increase dwell) I cant really see the heat being a problem if you mount them on the firewall, as long as it isnt above the turbo, and as for leads being a problem, Top fuelers run leads, as long as they are good leads and mounted well there wont be a problem there. If you increase the dwell with a remap it would give a great result, but without increasing the dwell, i believe it will be a waste of time to some degree, as the spark energy in theory will be less than the stock setup in good order.
EDIT!!!!
ive used VN coilpacks series 2 and wired them in this fassion
but the problem is its sparking both leads at the same time.... does anyone know if there is a way to make them ALTERNATE or am i looking at buying series one thats proven.......
heres a link that i got the main instructions off and its all exactly the same minus the coilpacks im using are series 2 not series 1
http://www.dsd.co.nz/coils.htm
its because they are a double ended coil. lol. not an issue. thats how they are meant to run. 1-6 2-5 3-4
well the problem is it is missing bigtime... it sounds like its only running on 3 cyls or 4 cyls
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
