Bendix Ultimate Pads
R32 GTST
Front: ??
Rear: ??
R32 GTR
Front: DB1170
Rear: DB1220
R33 GTST
Front: DB1170
Rear: DB1220
R33 GTR
Front: ??
Rear: ??
R34 GTT
Front: ??
Rear: ??
R34 GTR
Front: ??
Rear: ??
Approx Prices:
Bendix Ultimate DB1170: $100 pair
Bendix Ultimate DB1220: $80 pair
Disc Brakes Australia Replacement Rotors (Kangaroo Paw and slotted)
R32 GTR Front Rotors: DBA926
R32 GTR Rear Rotors: DBA908
R32 GTST Front Rotor: DBA4909
R32 GTST Rear Rotor: DBA908
R33 GTST Front Rotors: DBA4963
R33 GTST Rear Rotors: DBA908
R33 GTR Front Rotors: DBA4928
R33 GTR Rear Rotors: DBA4929
R34 GTT Front Rotor: DBA???
R34 GTT Rear Rotor: DBA908
R34 GTR Front Rotors: DBA4928
R34 GTR Rear Rotors: DBA4929
  • 1 month later...
  • 2 months later...
Originally posted by red900ss
Ferodo DS2500 pads. "Top shelf" item, for street and track.
R33 GTS25t
Front: FCP986H (box says 300zx turbo 3/90-)
Rear: FCP1372H (box says Subaru P1  99)
Not cheap, but worth every cent imho. :uh-huh:
What sort of price?
I need new front pads before I head off to the track and I need bushes apparently too.
  • 6 months later...
hey Joel, they changed the parts numbers about 6 months ago, putting 4 in front for the 4000 series rotors (direct replacement) and 5 for 5000 series (2 piece rotors). Yours were probably in stock for a while somewhere.
I will need to change my rear brake pads too.. tis is GTT R34, is there a good brand that is reasonably price that I should get? :mad:
Hey I just changed to Bendix Ultimate from the standard ones and noticed a big improvement. Did it after going around Eastern Creek with Duncan in his GTST (with Ultimates) and realising after about 5 laps that I wasn't going to die despite the fact that he was happy to be doing 140km/h 30 metres from a hairpin.
They are very dusty though.
Go the Ultimates Yotis. I just did after riding with Duncan and realising after about 5 laps that I wasn't going to die despite the fact that he was happy to be doing 120km/h up a Porsches arse 30 metres from a hairpin.
Heaps better than standard ones but very dusty.
LOL.. ok :(
  • 3 months later...
EBC Green is for cars up to 750kg according to a recent sales brochure. We find they also ware out at the track way too fast which seems consistent with the weight issue so stopped selling them years ago
  • 5 months later...
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
