he's having the same result without the ebc. so it's not that
i reckon your highflow cat doesnt flow too high. alot of these so called highflows are crap. i had an xforce 3" hf cat on mine, it ran like crud, so i put the 2.5inch back on, much better. now i'm looking around for a magic cat or metal cat stainless type with the big 5" body.
have you checked that your cat hasnt collapsed?
  • Replies 81
Posted Images
CES are taking the cat off tomorrow to check it for damage, most likely put a metal cat on as it was just a bigger ceramic jobbie they put in last time, also going to look at the resonator for collapse.
seen this kinda thing before, melted cat baffle/muffler/resonator = zuast blocked and poo results
also if ur using a bleed type bc they tend to drop boost out at higher rpms
Getting the same result with EBC, HKS actuator set to 15psi, turbotech, stock actuator, gypsy curse....you name it boost drops.
Also another note, pressure measured before and after I/C is the same, no restriction there either
unbolt the zuast from closest place to turbo (after dump before cat would be best nothing in the system but pipe) run the car see if it feels the same,
take off the snorkel or watever infront of the turbo and give it a visual inspection (check blades ect)
have u got a tuneable ecu or anything (has it reset)
best way to work out a problem is by excluding the possiblities
good luck Quigga
Have you got the standard induction pipe ??
could that be sucking closed and causing restriction ???
R34 intake pipe doesn't suck closed under boost, we watched it and the way it's designed is clever, it contracts and forms a rigid wall with the groves interlocking...the centre doesn't collapse at all contrary to myth.
And yes everything else has been checked, ECU is fine etc etc
My original feeling that the exhaust has never been flowing what it should still stands, for my car not to gain 0.1psi after getting a full turbo back is sus. Anyways should have answers in about 5 hours :fakenopic:
Ack!!! It's not the CAT, either way I stuck a 500hp rated one on, as if things do go the right way the 400hp jobbie will then cause me grief!!!
Anyone want to buy a 3" Ceramic substrate CAT rated at 400hp? lol PM me
make sure, because it does happen, i've seen it, i've got it on DVD :( and it ahppened at about 14psi from memory, with a hi-flow, so similar to your setup
Edited by VB-
make sure, because it does happen, i've seen it, i've got it on DVD :thumbsup: and it ahppened at about 14psi from memory, with a hi-flow, so similar to your setup
Looks like I'll have to revisit this avenue again and put a reinforced pipe in as it's my last viable option before I take the car down the back paddock and shoot it. Anyone got an EVO 7 they want to give me??? :thumbsup:
Took the exhaust off, no improvement, if anything boost tapered-off quicker
Blocked off BOV...doesn't look like it's leaking, boost still drops off
Sat in the middle of a ring of mushrooms and prayed to the mechanical gremlins, boost still drops
It only leaves some intake pipe collapso issue that I can't see.
ive never seen it happan
I only just read about it when i bought that intake pipe off bass junky
but the more i think about it if that pipe gets some heat soak in it it would go pretty flexible and may even colapse the reinforcing rings
ive heard of ppl putting zipties in the grooves to stop it happening ,does this work ????
OK scratch the intake idea, just replaced the intake pipe with a reinforced one....same deal, boost drops off rapidly still :S
If this had been a horse it'd be off to the glue factory by now!!!!!
Ok so im gonna throw an idea out there, feel free to shoot it down everyone!!!
Instead of concentrating on the possibility of a "mechanical" restriction, is it possible that the soul source of power, i.e. the fuel, is being restricted??? Just seems strange that without any major internal restictions that the boost isnt steady. Trust me i know all about internal flow restrictions as i spent last year designing an intake system which had to pass all engine air through a 20mm circular restrictor (ahh good old Formula SAE :)). I know how painful finding the right balance can be!!!
Anywho, just a thought, maybe the injectors are clogged or shot, not enough "hot" exhuast gas to expnad to provide the boost level desired?
Maybe its time for some Wynns Spitfire :(
So did you test taking off the rear muffler like you said your were going to do originally. Could still be the wastegate actuator, I too have a HKS one and they're substantially smaller and lighter the standard item, maybe they're not up to the job...
I've done and tried absolutely everything, it's definately not a fueling issue as well.
Muffler has been off at the cat, boost still dropped-off.
Actuator is setup correctly, it did the same thing on an R33 actuator and a R32 one, all at different psi settings, each one dropped off nastily. I'm currently running 15psi on the HKS actuator, no EBC connected.
I'm getting annoyed with the bloody thing also
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
