he's having the same result without the ebc. so it's not that
i reckon your highflow cat doesnt flow too high. alot of these so called highflows are crap. i had an xforce 3" hf cat on mine, it ran like crud, so i put the 2.5inch back on, much better. now i'm looking around for a magic cat or metal cat stainless type with the big 5" body.
have you checked that your cat hasnt collapsed?
  • Replies 81
Posted Images
CES are taking the cat off tomorrow to check it for damage, most likely put a metal cat on as it was just a bigger ceramic jobbie they put in last time, also going to look at the resonator for collapse.
seen this kinda thing before, melted cat baffle/muffler/resonator = zuast blocked and poo results
also if ur using a bleed type bc they tend to drop boost out at higher rpms
Getting the same result with EBC, HKS actuator set to 15psi, turbotech, stock actuator, gypsy curse....you name it boost drops.
Also another note, pressure measured before and after I/C is the same, no restriction there either
unbolt the zuast from closest place to turbo (after dump before cat would be best nothing in the system but pipe) run the car see if it feels the same,
take off the snorkel or watever infront of the turbo and give it a visual inspection (check blades ect)
have u got a tuneable ecu or anything (has it reset)
best way to work out a problem is by excluding the possiblities
good luck Quigga
Have you got the standard induction pipe ??
could that be sucking closed and causing restriction ???
R34 intake pipe doesn't suck closed under boost, we watched it and the way it's designed is clever, it contracts and forms a rigid wall with the groves interlocking...the centre doesn't collapse at all contrary to myth.
And yes everything else has been checked, ECU is fine etc etc
My original feeling that the exhaust has never been flowing what it should still stands, for my car not to gain 0.1psi after getting a full turbo back is sus. Anyways should have answers in about 5 hours :fakenopic:
Ack!!! It's not the CAT, either way I stuck a 500hp rated one on, as if things do go the right way the 400hp jobbie will then cause me grief!!!
Anyone want to buy a 3" Ceramic substrate CAT rated at 400hp? lol PM me
make sure, because it does happen, i've seen it, i've got it on DVD :( and it ahppened at about 14psi from memory, with a hi-flow, so similar to your setup
Edited by VB-
make sure, because it does happen, i've seen it, i've got it on DVD :thumbsup: and it ahppened at about 14psi from memory, with a hi-flow, so similar to your setup
Looks like I'll have to revisit this avenue again and put a reinforced pipe in as it's my last viable option before I take the car down the back paddock and shoot it. Anyone got an EVO 7 they want to give me??? :thumbsup:
Took the exhaust off, no improvement, if anything boost tapered-off quicker
Blocked off BOV...doesn't look like it's leaking, boost still drops off
Sat in the middle of a ring of mushrooms and prayed to the mechanical gremlins, boost still drops
It only leaves some intake pipe collapso issue that I can't see.
ive never seen it happan
I only just read about it when i bought that intake pipe off bass junky
but the more i think about it if that pipe gets some heat soak in it it would go pretty flexible and may even colapse the reinforcing rings
ive heard of ppl putting zipties in the grooves to stop it happening ,does this work ????
OK scratch the intake idea, just replaced the intake pipe with a reinforced one....same deal, boost drops off rapidly still :S
If this had been a horse it'd be off to the glue factory by now!!!!!
Ok so im gonna throw an idea out there, feel free to shoot it down everyone!!!
Instead of concentrating on the possibility of a "mechanical" restriction, is it possible that the soul source of power, i.e. the fuel, is being restricted??? Just seems strange that without any major internal restictions that the boost isnt steady. Trust me i know all about internal flow restrictions as i spent last year designing an intake system which had to pass all engine air through a 20mm circular restrictor (ahh good old Formula SAE :)). I know how painful finding the right balance can be!!!
Anywho, just a thought, maybe the injectors are clogged or shot, not enough "hot" exhuast gas to expnad to provide the boost level desired?
Maybe its time for some Wynns Spitfire :(
So did you test taking off the rear muffler like you said your were going to do originally. Could still be the wastegate actuator, I too have a HKS one and they're substantially smaller and lighter the standard item, maybe they're not up to the job...
I've done and tried absolutely everything, it's definately not a fueling issue as well.
Muffler has been off at the cat, boost still dropped-off.
Actuator is setup correctly, it did the same thing on an R33 actuator and a R32 one, all at different psi settings, each one dropped off nastily. I'm currently running 15psi on the HKS actuator, no EBC connected.
I'm getting annoyed with the bloody thing also
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
    • Wife and I are still looking for a new home. One condition was a large enough garage for a full-size lift in one bay. Now if only we could find something... We've been looking for almost a year now.
    • Thanks everyone for the ideas! Sadly, ramps are a no go for me. With young kids at home, I do most of my work late at night while they're sleeping. Starting the car multiple times wouldn't be a great idea.  I'll go see one of those new long reach low profile jacks and take a couple measurements to see if they will fit.
