  • Replies 433
Posted Images
I'm after a front and rear set of QFM A1M or K750 pads for a S14 :thumbsup:
Front pads are the same as R32 GTS-T, Z32 etc...
Do you accept Credit card or Pay pal?
Let me know asap! I need these before June 9th!
I'm after a front and rear set of QFM A1M or K750 pads for a S14 :teehee:
PM Sent :geek:
Is there a chance of getting a price (if available) on the K500 front and rear pads for an R33 GTR with brembos
The k500's (and k750's) aren't made for Brembo's unfortunately. What you'd need to do is contact QFM directly, and organise for your backing plates to be sent up there so they can be re-bonded.
hi mark,
can i order a set of braided brake lines to suit '94 R32 GTR vspec II (with brembo)?
i really want to get the K750 brake pads (front + rear) as well, is there no other way of just buying them instead of sending your backing plates up? only reason is that my car arrives next month and i dont think that would be a possibility for me anyway. if not thats cool!
oh and let me know the payment options
cheers :D
Hey Mark,
You have $110.00 for stagea front lines delivered, do the stagea ones look like the ones in your pic.
Cheers,
Ryan
Hi Ryan,
Sorry for the late reply.
Yes the stagea lines look like the ones in the pic. The fittings might just be slightly different.
Cheers
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
