Hey guys, I own an R33 GTS4, got it professionally converted from an N/a to Turbo last week.
It runs really well now, just a few questions about it.
I have a FMIC etc now, but before the coversion I had a 3-3.5 inch momo exhuast system with a 5 inch tip(pretty big for an n/a) along with stock dump pipe and extractors and the engine gave a real growl, sounded awsum (most ppl throught I had extractors).
Currently i still have the exhaust system, but with a stock turbo dump pipe and stock turbo extractors and it is sooo much quieter then before, only at about 5k does it start to sound remotely grunty, someone please tell me why and how I get it sounding as it was before! Thanks
would a new set of extractors do it ?
Also, it is now idling at about the same, but the engine is reving very lightly constantly, from about 760rpm ~ 810rpm roughly, is this due to the turbo?
Thanks for the help!
Adam :laughing-smiley-014:
https://www.sau.com.au/forums/topic/177850-exhaust-note/
It is unlikely that you will ever get the same exhaust note. One of the beauties of a turbo is that it utilises some of the energy in the exhaust gasses to spin the turbine. If there isn't as much energy present by the time it comes out the muffler, then it can't emit as much sound.
As for yopur idle, is it on an aftermarket ECU or factory? As it's a RB25DE -> RB25DET conversion, I doubt a factory ECU could work quite right because it was designed to operate that exact configuration of engine. But, have a look at the AAC valve - it might be slightly gummed up and sticking, so give it a clean.
PS - it's THAN, not THEN - quieter THAN before
https://www.sau.com.au/forums/topic/177850-exhaust-note/#findComment-3246518
LOL thanks for the help and the english lesson! English me speak good :thumbsup: you better watch your spelling though --> "As for yopur idle" btw it has a new s1 r33 rb25det ecu, exactly the same as mine, except for being turbo, so I did not think that was the prob for idle.
I also just wanted to know how to make it louder again, would extractors make a decent diff?
Cheers Adam.
https://www.sau.com.au/forums/topic/177850-exhaust-note/#findComment-3246873
turbo cars will never be as loud as a N/A car. 3" on a N/A would be massivly louder than on a turbo.
you have 2 options firstly (and this should be done anyway) get a highflow cat and new dump pipe. this will make it a touch louder.
secondly you could cut out the centre muffler. this will add a bit more bark to it.
https://www.sau.com.au/forums/topic/177850-exhaust-note/#findComment-3247058
Thanks for advice, so extractors/headers will not make that much difference? only high flow cat and dump? Because I was planning to do them soon enough anyway.
Thanks again, Adam.
P.S wot about the idle issue?
https://www.sau.com.au/forums/topic/177850-exhaust-note/#findComment-3247090
If you have mufflers, remove both mufflers. If you hvae them replaced with straight pipe, it should be louder and sound meaner.
Cat - same deal
Bigger dump/front pipe makes a bit of difference but nothing like changing mufflers.
Bigger turbo makes a huge difference to the exhaust note and volume. - after all, this is essentially the only difference between what you used to have and what you have now - think of it as a big butt plug in the exhaust (literally)
https://www.sau.com.au/forums/topic/177850-exhaust-note/#findComment-3247886
Thanks for the advice guys, I am running a stock ecu, from a s1 r33 turbo, so the same as mine + turbo, which I thought was good, and the engine never did this before... I thought it was the turbo setup that did it? please advise.
In terms of taking out mufflers etc.. I may consider removing the system (middle) one, as it is a b*stard over speed humps, but I don't want to make the car more illegal then what it is.. considering I am a P plater... Plus I am really happy with my current exhaust sys.. just hoping the cat etc.. could be fixed up..
No one has mentioned the extractors... are they not as good on turbos as they are on N/A's ?
And thanks for the butt plug explanation.. it all makes sense now :laugh:
I did give the car a bit of a go and at 5k it is pretty mean.. nuthing what it used to be...but anything below sounds as quiet as a little civic.. no offence, small price to pay I guess. :laugh:
Cheers, Adam :laugh:
https://www.sau.com.au/forums/topic/177850-exhaust-note/#findComment-3248034
if you want more noise you could go a screamer pipe, but on the stock turbo it can leak a bit, and will only make it louder when it comes on boost. and is rather illegal.
but do you really want extra attention from police, with the increasingly strict laws that keep bringing in?
https://www.sau.com.au/forums/topic/177850-exhaust-note/#findComment-3248321
there are no extractors on a turbo sky. it runs an exhaust manifold which the turbo bolts to and then the exhaust itself runs out of the turbo.so its like a small combinatioon of pipes (6 of them) that run to the turbo, then a dump pipe from the tubo throught 2 the front pipe and then the exhaust begins.
when you talk extractors on a turbo skyline, your talking front piep and dump pipe. they can be an all in 1 system like FLYN sell or a split dump front like just jap sell.
FLYN - http://www.skylinesaustralia.com/forums/in...howtopic=166815
JustJap - http://www.skylinesaustralia.com/forums/in...howtopic=155238
as for note, wanna make it louder, remove the rear muffler, im guessing its and oval type muffler and replace it with a cannon muffler.
https://www.sau.com.au/forums/topic/177850-exhaust-note/#findComment-3248417
i stand corrected. well then just change the front pipe and dump as well as ur rear muffler to a cannon and away u go. i had a kakimoto 3" system with cannon muffler first and at idle i was 97dB and at full noise i was 108dB, that was loud and after a while the drone got to me.
so yeh put a cannon on.
https://www.sau.com.au/forums/topic/177850-exhaust-note/#findComment-3248587
Thanks guys,
Very helpful, I decided I will change the dump pipe and cat, as well as remove the middle muffler. Think that should give me a decent increase in growl, I'm definitely not after drone, even if it means sacrificing volume. Thanks a lot for the help! :fakenopic::D
Power wise though, a 3.5 inch sys and 5 inch tip is definitely big enough for a turbo to blast out exhaust fumes? I thought it would be.
Thanks, Adam
https://www.sau.com.au/forums/topic/177850-exhaust-note/#findComment-3248628
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
