hey all
i have a dilemma
i have a kaaz 1.5lsd that isnt locking anymore... ppl tell me all i need to do is change the oil (hasnt been changed since the car came to oz) n it should lock again, but i think i want a 2way..
now unless someone wants to directly swap me a 1.5 for a 2 way id be more then happy to.
i dont care about tire wear, noise, clunks ect, i just want 50/50 lock
do i shim it to make it really tight?
or do i weld it for good.
only reason why i dont wanna weld it is that im running 240rwkw n dont wanna be breaking driveshafts.. i have a rb25 box, that should be fine with 240 + weld right??
cheers!
https://www.sau.com.au/forums/topic/177909-to-shim-or-not-to-shit/
cheers!
what are you using it for?
you won't break driveshafts with it boc-locked, but you will have to be on your game in the wet
and of course, it'll be illegal for street use
the rest of this thread has been pointless :pirate:
shimming it is a povo way of increasing the pre-load.
if it's a drift car, minispool. had one in the R31 and it loved being sideways.
if it's a street car, get the 1.5 way sorted. locked diffs are illegal and dangerous in the wet, and they compromise the handling badly unless you ARE sideways.
Well i went off and bought a whole new diff which is locked, that solves my 1.5 problem, if the locker shits me, i will sell the locker n rebuild the 1.5 i guesss
how is a locker so dangerous? are we talkin that it just make u spin heaps easy?
when will i have handeling problems? at high speed? or just around a corner?
Thing with lockers is that it effectively isn't a diff at all. The inside rear wheel will always rotate at the same speed as the outside.
To the in-experienced, it will understeer a lot and you need to use aggression at all times to get it to turn a corner. This is why it can be dangerous. Once you are used to it, I am sure that you will be fine.
Edited by Thunderbolt
I currently have a welded diff, making 400+rwkw, and all I can say is it's hell nasty on the street, but bareable on the track/strip.
I'm in the process of getting a shimmed GTR diff put in so it's not such a pig on the street.
I installed the diff today
just got back from a 4 hour mountain run, there was a tad bit of understeer but only when speeds were under say 40km and we went around a fairly sharp bend... nothing dangerous at all, understeer (caused by the diff) wasnt noticeable at high speeds
my front tyres were causing more understeer then anything
in the car park the inside tyre just spins, no clunks, no ugly noises nothing, im actually pleased with the way the diff is behaving. its far better when other lockers + mini spools i have been in
straight line traction (take off, + i used to have wheelspin in 3rd) has increased so much i cant believe it.
overall result
big smile on my face :whistling:
Edited by DjeMz
overall result
big smile on my face :P
people wont tell you but a locked diff will give u bad understeer so much so u wont have the adjustment of castor in the front end to fix it.locked if u want to drive sideways 90% of the time otherwize ur just making huge wear on axles,tyres and drive line.I use a locker in my rally car but thats a rally car :cheers:
    • Welcome to Skyline ownership. Yes, it is entirely possible parts websites get things wrong. There's a whole world of inaccuracies out there when it comes to R34 stuff (and probably 33 and 32). Lots of things that are 'just bolt on, entirely interchangable' aren't. Even between S1 and S2 R34's. Yes they have a GTT item supposedly being 296mm. This is incorrect. I would call whoever you got them from and return them and let them know the GTT actually uses 310mm rotors. Depending on where you got them from your experience and success will obviously vary.
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
