depends how much money you have to burn.. if you can afford to rebuild your engine in the very near future then heck... why bother with a crank collar?
So if fitting an N1 oil pump a crank collar is required yes?
https://www.sau.com.au/forums/topic/177992-crank-collar/#findComment-3248610
The reason i ask is that i have a spare s1 rb25det that im going to rebuild while its out of the car.
I have got my hands on some reasonably priced rb26 rods, got some wiseco forgies on the way, what else should be on my checklist?
Power goal is 300rwkw
Edited by hecticrb25
https://www.sau.com.au/forums/topic/177992-crank-collar/#findComment-3248616
as long as your support systems are all up to the task (injectors turbo cooler manifolds etc) sounds like your on the right track. Just make SURE you invest in the crank collar because its worth its weight in gold compared to rebuilding your engine again.
https://www.sau.com.au/forums/topic/177992-crank-collar/#findComment-3248630
i am going to take a different approach to the usual "do a search"
http://www.skylinesaustralia.com/forums/in...howtopic=110680
go there. there is all the information you need for the oil issues. IF your not going to be revving it past 6500 every gear change you probly wont need it. But anyway read that thread.
Check the forced induction guide for more info
https://www.sau.com.au/forums/topic/177992-crank-collar/#findComment-3248659
NP's =)
oh btw high octane sell the restrictors so go to www.hioctaneracing.com.au if you need to buy one.
I have made 363rwkw outta my 25/30 and i only have the restrictor - i did not go for the drain back from the back of the head to the sump (but i dont do any drifting or track racing)
Edited by Guilt-Toy
https://www.sau.com.au/forums/topic/177992-crank-collar/#findComment-3248669
there is a JUN one for sale on the for sale section at the moment.
I have purchased 4 or 5 of them so far from Pro Engines. Very good service and they get it to you very quick as well (providing he has them in stock)
taken from www.proengines.com.au
Contact Pro Engines
Phone: 0448 826256
E-mail: [email protected]
Address: 18 Stephens Road Queanbeyan, NSW 2620 AUSTRALIA
Payments: We accept payment by Bankcard, Mastercard & Visa. Also Direct deposit and Palpal.
where can i buy a crank collar kit for my rb26 i cant find a link to buy them!!! peaple say they are for sale but where? websit please!!
Edited by Guilt-Toy
https://www.sau.com.au/forums/topic/177992-crank-collar/#findComment-3248681
Okay so here is a list of parts that i have/will be getting. Aim is 300rwkw.
RB25DET S1 in a S13 silvia.
Jun Crank Collar
Standard RB25DET Crank
R33 GTR Rods
Wiseco Forged Pistons + Rings
Oil Restrictors
Engine Balancing
N1 Water Pump
N1 Oil Pump
???cc injectors
bosch 040 fuel pump
GTR intercooler
Greddy intake plenum
Valve Springs
Tomei Poncams
Is any of this overkill and am i missing anything?
https://www.sau.com.au/forums/topic/177992-crank-collar/#findComment-3248722
Paul
There is no made up kit. I could put one together but it would cost too much money and i wouldnt even be able to sell them because they are really easy to make.
All you need is the JUN 1.5mm restrictor which is available from hioctane (details above) OR from Japan Nengun www.nengun.com he sells them as well.
The collar is available from Nengun as well but its a bit more expensive then the version from Proengines in Canberra.
Then if you read the oil controll thread that i linked above you can see pictures and details on how the drain back to the sump was made and you can source the parts and fittings from your own local sources (speedy fitting etc etc)
all it is.. is a drain back from the back of the head to the sump thats it. very easy once you have it appart and know what has to be done. Check the pics
DID i mention to read that oil controll thread ? just double checking that i did.
im located in the usa im in need of the crank collar kit/the proper oil restrictor(whats the proper one?), and the head drain return kit! is there an online website that sells rb26 stuff like that or an rb specialist website to research and find stuff for sale like that?
https://www.sau.com.au/forums/topic/177992-crank-collar/#findComment-3248725
are you going to get solid lifters? i kept the stock ones and they are starting to cause me some issues when try to push more then 360rwkw.
Anyway Nismo 740cc injectors are the only ones i reccomend. they will do fine for your power level and there will be room for more power later on if needed (4 hole injector's are your friend)
Jun Crank Collar
R33 GTR Rods
Oil Restrictors
Engine Balancing
N1 Water Pump
N1 Oil Pump
???cc injectors
bosch 040 fuel pump
GTR intercooler
Valve Springs
Tomei Poncams
https://www.sau.com.au/forums/topic/177992-crank-collar/#findComment-3248734
as a general rule your valve springs and lifters should be ok if they are in decent condition. its only when pushing them harder when you have issues.
My whole rb25 head is stock - stock cams stock lifters and stock valve springs and i dont have any issues at 360rwkw and might be able to get a little more but i dont really need anymore power.
Reason why i asked is because your getting after market cams which may put extra stress on them.
Will the hydraulic lifters f*&k out at my power aims + a bit?
https://www.sau.com.au/forums/topic/177992-crank-collar/#findComment-3248789
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
