Hey guys
Id like you recommendations for a R34 GTT brake pad and its code or style if you have it as the stockers have been boiled and brake like crap.
ive heard a few suggestions but interested in a set for the front for about $150-$200 best bang for buck really.
Ive read about a few 3000s and 2500 being the most common but looking for other suggestions too.
Have to be high temp not much track work just a little, more so for road use. would prefer to stay away from bendix
Thanks
Nathaniel
https://www.sau.com.au/forums/topic/178162-r34-brakes/
For road use why not just get standard nissan pads.. They do the job quite well
i had stock pads in the front on track day and i had no dramas.. This was in the 33, so i would assume no problems for your car either..
Otherwise i have used project mus before and i love it.. If i didnt get the standard pads for cheap, i would have bought another set of project mus
Those are under 200 :)
ps.. what a real life example of standard pads working quite well?? well tonight i was easily doin 120 around a corner up a hill.. truck pulls out around the corner.. i lock up.. in short- i stopped in time.. brakes worked very well :) for standard pads
heheh just my 2cents..
Edited by siddr20
https://www.sau.com.au/forums/topic/178162-r34-brakes/#findComment-3252137
bendix soft compound brake pads are aus std and are the ones recommended.. i have a hard compound pads that squeel now (which is quite normal) but im in the process of getting it fixed. These ones are racing pads and work best when they get heated up...
Edited by iMessenger
https://www.sau.com.au/forums/topic/178162-r34-brakes/#findComment-3254148
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
