hi guys, u may think this is a noob question, but i have hit the power wall. i would like to get some more power out of my r33 gtst. atm it has an upgraded t4 turbo, ssq bov, 720cc injectors (dont ask, dont know why they work), Bilstein heavy duty suspension, front and rear strut bars, nitrided crank, fmic, 3" exhaust and im probably forgetting something.
the turbo will soon be upgraded, a screamer pipe, safc and a tune/remap are on the way. i am also thinking about a z32 afm.
i would like to know from your experience and expertise, whether there are any good mods i can do with a budget, to gain more power, atm the clutch can handle 420kw.
i am probably pushing 190-220kw, which is just a guess atm, will know more after dyno.
furthermore i am thinking of investing in its support systems later on
any and every piece of advice is appreciated thanks.
Edited by r33cruiser
How are you running 720cc injectors without management?
You dont have management listed as a current mod, only a future one... so 720's = impossible :)
And i also dont get a nitrided crank either!
For basic mods, see here:
http://www.skylinesaustralia.com/forums/in...showtopic=45218
For more results, so you can relate that to parts
http://www.skylinesaustralia.com/forums/in...showtopic=55845
And a couple others
http://www.skylinesaustralia.com/forums/in...showtopic=46711
http://www.skylinesaustralia.com/forums/in...=steve+3037+hks
There are but a small few of the good threads you can find :)
Also setting a budget for everything helps to get more accurate responses
And a couple others
cheers all the mods bar the fmic and strut braces have been done by previous owner. ive only had car since january.
i will definitely check out ur links, budget is about $3000
You could have made 200rw will stock turbo and stock injectors - sounds like what you need is a power fc or somesort of full engine managment to get what you have running properly and efficiently.
thanks heaps, the responses i have been getting is to invest in electronic support systems.
i will definitely have a look around.
no, its a 5sp manual
thx
thx
Yeh definatelly get an ecu and if you can the power fc is probably your best bet - hard to find nowadays though. That way you can tune it and make the most of your bigger turbo and injectors - should have nice power then. :)
Stock turbo
3" turbo back exhaust
Intercooler
Fuel pump (eg: bosch 040)
and something like 12psi should get you anything between 190rwkw-210rwkw depending.
It wouldn't hurt to get an SAFC II, fuel only computer, to keep the fuel at a safe level and AFR down to a safe level.
With a tune on the dyno you can push over 200rwkw+ on stanard ECU running the above + SAFCII.
But depends how much you want to spend. Since you already have a T04, get a fuel pump, and an after market ECU and get it tuned. You will make some good power.
Hope that helps.
Thanks,
Abu
Edited by abu
definitely thanks. thats perfect i want to have about 250kw if possible, and maybe more, just to beat a few mates.
at least on this forum i can listen to people that have done it before, some engineers i have questioned dont know shit about imports.
once again thanks, i will look around for a better ecu/ power fc and a fuel pump.
I still dont understand how you have 720cc injectors with a stock ECU
theres alot you may not understand, but it works and thats all i care about, that is one of the reasons i purchased this particular car.
all those extras with no ecu upgrade.....
you should be upgrading ecu if u go down the bigger turbo/bigger injectors road.....
yea, ive been thinking about it for a while, im just waiting for a good unit to come onto the market.
I know enough to know 720cc + stock ECU = no chance
:laughing-smiley-014:
Yeh doesn't make much sense, any sense really, even with a simple fuel computer they would flow way too much and the ammount of correction applied would be astronomical. Perhaps either they are not 720cc or it has some crazy re-mapped jap ecu that he is not aware of...
hey guys, just throwing it out there,
does anynone know a ball park figure for a full tune?
any suggestions would be helpful
Depends what your tuning...
safc around 150 -200
Power fc around 400 - 500 perhaps, each car / ecu is different.
I'm contemplating a power fc or if i can't find one maybe I'll go with emanage ultimate. :) safc has gotten me to 195rw so far so its doing an alright job on a reasonably safe tune i.e between 11.5 and 12 afr. :)
k sweet, i'll tell a few mates, also-im talking too much
but when i get all these mods done, will it be safe to drive around for 1-2 wks untuned. until it is tuned?
cheers
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
