hey everyone
who can tell me which turbo to get for a nissan s13 silvia
the motor is a rb26 head with rb30 bottom end (not built yet)
the rb26 cylinder head
*head ported
*in/ex hks 280 degree 10.2 lift camshafts
*jun titanium retainers
*hks valve springs suit camshaft
*standard valves, 3 way valve angle maybee 4?
*tomei solid lifters
*hks metallic gasket kit
*cometic head gasket
*tomei cam cap studs
*arp head studs
*standard throttle bodies and plenum
*hks 1000cc injectors
*hks 11.0mm fuel rail, sard regulator
*hks adjustable cam gears
*hks cast iron low mount
*hks 50mm wastegate
bottom end rb30
*rb26/30 cp pistons
*billet argo rods i beam
*acl race bearings
*arp main studs
*ross balancer tuff bond
*n1 water pump
*jun oil pump, crank collar
*high energy sump 8.5l
i am capping the car at 800hp i doubut i can get it from pump fuel? but want to see the car at the drag strip with race fuel and slicks......just to brag 9's...lol
is the trust t78 better? i hear t04z has little lag
most of my things are hks so i'm leaning towards the t04z.... The cars goning to be a drift car and street drag car
what is the most rwkw's from this turbo
are all rated at 800hp? why get a bigger wheel ar100 if the smaller 1 ar63 is same hp rating?
thanks
josh
https://www.sau.com.au/forums/topic/178356-hks-t04z-vs-trust-78/
  • Replies 67
If drifting is your main focus, neither of those turbos will be any good at all.
Too much lag and not enough response, peaky power delivery and poor throttle adjustability (important in a drift car!!!)
A few of the (expensive) parts/mods on your list would be over-kill for an RB30DET built to make a nice, responsive, 450 to 500hp- which would be more than enough in a light drift car like a silvia with the right suspension set-up.
so cap it at 450hp - 500hp
would it have traction for the street?
and turn it up for when acting the fool....lol
is it possible to do this?
That's about the MAX you would want for a street car mate.
Like many have said, if you want a 'good' drift car, you're gonna need a responsive car.
But for which turbo to go ahead with? I would go the HKS T04z because it's newer technology?
yeah i'll get the t04z
i want to convert the silvia to 4wd now
not right away though... i got a 300zx box an rbr26 bellhousing for now
its been done before
http://www.nissansilvia.com/forums/index.p...howtopic=224266
i'll give it a go... further down the track
thanks ppl
hey
i got a hks cast iron low mount manifold
it has a t04 flange
and for the top it has a td flange 3 bolt for the wastegate instead put a turbo
my point is if i put a smaller trust td..... something (which one should i get)internal gate
and get a garett 3035r 700hp turbo d xr6 turbo also internally gated or smaller turbo?
then the car would spool up quick for drift and the big one would kick in later for drags
let me know ppl
Hoenstly mate, i think you really really need to do a lot more reasearch.
Your ideas sound very up in the air, let alone the budget.
Running a 400rwkw+ car is going to cost you upwards of 20k without even sniffing.
Probably closer to 30-35k by the time you replace everything you break when you try to start using the power
Yeah mate I really think you need to go back and have a look at the basic shit before youre doing what youre talking about doing...
Takes a lot of commitment and huge amount of cash to have a car running an engine like that...
Why do you think you dont see them everywhere? For just that reason, most people dont have the money, dedication, nor want to live with the compromise.
And I assure you, if you think youll be driving 800hp round on the street, there WILL be compromises :D
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
