what you need to get into your head is that the requirements for a drift car and a drag car are completely different from a power delivery and chassis set-up point of view
trying to build a 'hybrid' to do both jobs will result in a car that is compromised for both diciplines
to just 'turn the boost down' at the drift track won't help with regard to response- what you need for drift would be to use a turbo that will be able to make around 500hp with the smallest exhaust turbine size possible (somewhere around the .6 A/R range)
you'll notice in your video that even at freeway speeds, and changing at redline, the 3L R34 still had a brief pause after gear changes- this wouldn't be great on the drift track
  • Replies 67
okay i think i'll just have the car as a drag car and for burnout comps
i got a rb25de non vct head.....but i'm selling it on ebay now
i could have built another motor rb30det for drift
but whats the most rwkw from the hks t04z?
if i were u i woiuld keep the s13 an sr20 put an s15 turbo on it get about 200rwkw and drift that.
and with all the money u reckon ur gonna spend on this rb26/30 conversion get a gtr 32 and build that into ur street drag car.
and do heaps of research i reckon'
btw how old are u?????
u sound like my 9yo cousin the way u speak.
22 2day
Happy Birthday!
You say you wanna drift in a 400rwkw car, do you know how to drift by any chance or are you planning on practicing in this car? Because if you're learning in this car chances are you're gonna....... BAM!! $30k+ GONE!! sort of...
yeah thanks
i was trying to learn in the s13 silvia but it has a open wheel diff and ca18de has no power
will be getting a 2 way nismo diff and 5 stud conversion soon
any one watch that youtube lean to drift by the drift king... some one translates it to english
you know d guy he wears gloves cozz hes 2 good
i will learn b4 d motor is in coz i dun wanna wreck nuthin
im getting my tein super drift coilovers this week
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
