I never get why people come on here to tell people im going to put this and this on my car (copy and paste someones shopping list from another thread) and say they are putting it into their car and then ask a bunch of stupid questions when they obviously have no idea what they are talking about.
Seriously, do you kids have nothing better to do?
Shouldn't uz be touching urself to a cheap porno or something at this time of the night?
  • Replies 67
you guys keep bagging me out
you ask and learn......lol
:D
Its ok....you have a few posts...and 1 rating.... :(
It is always right to ask questions.....so you may learn.
But it is more important you read some sticky's...ie Turbo upgrades etc
before you ask a question about turbo choices etc..for a car you have built in your head.
i bought the silvia ca18de manual for $2500...lol
i bought the vl commodore for $300 ...lol ...cheaper than buying the motor alone
instead of buy a gtr i will put the money into this motor....makes sence
Did the VL come with a RB26?
Did the Silvia come with 4 Wheel drive?
You are going to build a 3L 1986 non turbo Nissan motor.......let me think...into
a kick ass turbo charged monster..then put it into a silvia..what year?....1994......
ITS CHEAPER BUYING A GTR...........
Its all good to be an individual...but the heart ache and the troubles you are getting in....OMG :thumbsup:
I want what you are on? :laughing-smiley-014:
gtr weighs to much....but adding this motor and 4wd system not sure how light the silvia would be
it will be unique....if i could go back i would
its a 1990 model silvia
GTR weighs too much.......you think that dropping a RB30/26 into a AWD nissan silvia will be much lighter?
The conversion has been done many times........on a RB26 motor..I believe SS or N1 turbo's where
used with a good set of cams (Tomie Poncams) to encourage response and mid range performance
and yes....forged and good bits where added to the engine for relaibility.
On a RB30DE..have never seen it done..let alone a Turbo fit......usually a Turbo motor is used.
Anyway...good luck with your project.
It wont be any lighter by an amount that would make such a thing at all worthwhile
you're going from alloy 4cyl to cast iron I6, plus all the associated AWD gear
complete woftam really. but would be a laugh if anyone could be bothered spending the time and moneh to do it properly
you've going from alloy 4cyl to cast iron I6, plus all the associated AWD gear
My thoughts exactly :thumbsup:
I believe Jay ran the T78 on his 2j in his cressida. Mild cams, plenum & exh. manifold.
That pushed out ~450rwkw. Not sure if that was on pump fuel, never asked.
That in no way looked laggy for such a big turbo; He said it used to come on strong a little after 4k.
Jay rana 10.1 @ 143mph with a manual. :glare:
Darrens R31 ran a 10.2 @ 140mph with a GT42/45 no transbrake and some where around ~450rwkw 2speed glide. That too comes on strong a little after 4k.
The mph's are good for a 9sec pass
hi guys
i need somone to confim this for me
i know a rb25 sump fits the rb30 block fins have to be cut down
will the rb25 gts4 sump fit the rb30...i know the rb30 will need bolts retapped due to larger gts4 bolts
the rb30's crankshaft is going to be knife edged....but i'm reconsidering it
it will be linched otherwise....due to the lighter pistons/rods....
i hear the 4wd sumps are no good on circut cars etc.
and people use dry sump set ups
its gonna acost around $1000 for a good oil pump $900 for larger sump
thinking of using morosso dry sump accessories
has anyone seen a tread or site on how to set up a dry sump?
please answer top question
i heard that the hks t04z version has a special exhaust valve for quicker spool time
the garrett one doesn't have this
any one hear about this?
Yeah it has a xenon push pull spool up valve you connect to your nitrous bottle. When you hit boost it opens the screamer pipe. Great for doing burnouts during the school holidays.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
