hey guys i am letting go of some parts i have laying around the garage!
here we go..
1- turbo timer! $70 $50
2- r32 lowered and stiffened springs! SOLD
3- VG30 turbo with broke seals lol! SOLD
4- malpassi fpr! $100 $90 $70
5- gtr rear spoiler in burgandy exc cond! $150 $100
6- 16inch avs model 6 rims with 97% new tyres. $800 $700
7- EOI- rear pods, side skirts.
as seen on pic above!
8- greddy style BOV. $100 SOLD
prices are SLIGHTLY neg. and will post at buyers expense!
cheers.
Edited by rad33
https://www.sau.com.au/forums/topic/178441-r32-parts-and-pieces/
hey as per my previous 4 or 5 PMs about 2 months ago, im still want the VG30 turbo!
my one has a buggered compressor wheel as the cat knocked a oil filter of the shelf onto it..... damn pussy!
can you please PM me back!
cheers,
Andrew
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
